SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: What size of wheels everyone has on their SL?
Old May 22, 2006 | 01:30 PM
elau's Avatar
'87 W124, '95 R129, '04 G35
It appears that upgrading the OEM wheels are the most favorite mod that SL owners do to their cars. I am wondering what size wheels you all use? I purchased a set of 19" staggered and should arrive later in the week. For tires, I ordered 235/30/19 front and 265/30/19 rear.
For those who has 19", how is the ride and do you need to have the speedo re-calibrated?
Old May 22, 2006 | 02:10 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
I ride anywhere from 16inch to 20inch........ about your 19inch....you using the wrong size tires.......... the right size tires would be 245/35/19 front 275/30/19 or 285/30/19 rear...... the ride on the 19inch is bad if there a lot of pothole on the road........ wrong size tires would have your speedo read wrong.. and your ride will be bad too due to the wrong sizes tires...so you better change your tires.....good luck.....
Old May 22, 2006 | 04:19 PM
elau's Avatar
My typo. My front is 235/35/19.
So, if my setup is 235/35/19 F and 265/30/19 R. Will that work?
Old May 22, 2006 | 08:16 PM
HLG600's Avatar
2009 SL63 AMG
I have 18's and run 245F with 275R. How wide are the rims themselves? Mine are 8.5F and 9.5R.
Old May 22, 2006 | 10:06 PM
SL BRABUS's Avatar
No.......
Old May 22, 2006 | 11:16 PM
elau's Avatar
Thanks guys!!! I will re-order my tires tomorrow to 245/265 setup.
By the way, this is my first mod, ever!!! Hope I won't get bitten by the mod bug for a while after this one
Old May 22, 2006 | 11:33 PM
SL BRABUS's Avatar
245 and 275.......... .......just kidding.......Really you should get it right 245/35/19 front 275/30/19 rear.....good luck.....
Old May 23, 2006 | 07:26 PM
l5foye's Avatar
If you mess about with different tyre profiles, you will find the cruise control will not work. A simple test is -mark a front and rear tyre at same place (eg 90 degrees), roll car forward a short distance, if tyre marks do not line up, then generally cruise control will not work.
Old Jan 17, 2007 | 07:55 PM
artist_sl500's Avatar
Tire sizes...
Is the different sizes to make up for staggered setup?...The wider rear?
The hight will remain the same correct?
Thanks,
Steve
Old Jan 17, 2007 | 10:06 PM
SL BRABUS's Avatar
Thanks,
Steve
yes........ the overall diameter will remain the same........
keep in mind to get the same diameter...... you would have to run tires size show here.....
225/55/16 all around
235/45/17 front 265/40/17 rear
245/40/18 front 275/35/18 rear or 285/35/18 rear (will be off dameter by 2mm but wider no problem)
245/35/19 front 275/30/19 rear or 285/30/19 rear (will be off dameter by 2mm but wider no problem)
245/35/20 front 275/30/20 (will be off dameter by about 10mm that a problem but people do it anyways)
hope this help good luck.......
Old Jan 18, 2007 | 01:02 AM
Bigdot's Avatar
some
19" with 295 in the rear!
Old Jan 30, 2007 | 10:11 PM
darcysl's Avatar
Question
Can you recommend somewhere onling to get the exact same tires/wheels you have. I like them a lot and I still have stock rims. Ball park price??
thanks
Old Jan 31, 2007 | 12:09 AM
OJwerks's Avatar
not stock.
No.......
i have to disagree.... 235 front & 265 rear may not be the most aggressive setup you can run on an R129, but that does not mean that they will not work, that setup will work fine.... if the man already baught the tires, them burn them up and make sure that your next set is the recommended tire size.....
btw, im running a 265/35R18 rear & 225/40R18 front in my SLK and the cruise control works fine... also, i only have speedo error of 1-3mph tops...
Old Jan 31, 2007 | 02:41 AM
SL BRABUS's Avatar
It like saying..... putting 89 octane gas in your car..... sure it run..... but it not recommended...... I hope you get my point........
Old Jan 31, 2007 | 02:19 PM
AMGSport's Avatar
I love the look of 19's; I don't like the ride. I had AMG Monobloc's and liked them, but I like to see some rotor and caliper. I opted to go with 18X8.5 in front and 18X9.5 in the rear as shown below.
I'm knew to the forums, so I won't post the link to where I bought these rims, but I'll share if anyone is interested.
Attached Thumbnails What size of wheels everyone has on their SL?-18_fm5_machined_01.gif
Old Jan 31, 2007 | 03:05 PM
mebeJOE's Avatar
SL500 2001 Formula 1 Edition;
I don't know if this helps, but just for reference, here's what mbusa.com says was standard equipment for some of the years:
2005:
Wheels Standard aluminum-alloy 5-spoke design, 8.5 x 18 front, 9.5 x 18 rear.
Tires 255/40 R18 95W front, 285/35 R18 97W rear, high performance2.
2003:
Wheels 7-spoke aluminum alloy wheels, 8.5J x17 front and rear.
Tires 255/45R17 98W, all-season high-performance tires.2 Collapsible compact limited use spare tire on lightweight wheel, with portable electric air compressor (plugs into lighter socket).
2001:
Wheels 8.5Jx18 front and 9.5Jx18 rear aluminum alloy, AMG monoblock thin-spoke design.1
Tires Steel belted radial 245/40ZR18 front and 275/35ZR18 rear, high-performance.1,2
1998:
Wheels Aluminum-alloy 8Jx16H2, 6-hole design.
Tires SBR performance steel-belted radial 255/55R16 100H all-season.
1996:
Tires Steel-belted radials. Performance 225/55ZR16.
Wheels aluminum-alloy 8.0Jx16 H2.
1991:
Wheels 8.0Jx16H2 aluminum alloy.
Tires 225/55 ZR 16 steel-belted radial
Old Feb 4, 2007 | 11:35 PM
jjay911's Avatar
1991 300sl 5 speed manual
If money is no object. Then 20s plus the correct lowering height and tire size, plus shocks and springs will make quite a ride. I have no ride problems with this set up. It did cost a bunch though
Rims 5,800
Tires 1,700
Shocks springs plus instal 800
JJ
