SL/R129: Would AMG MonoBlock II fit?
07 Z06, 08 Rover Sport, 03 Dmax, 13 Diavel
I have a friend interested in buying my AMG E55 wheels, the monoblock II in the staggered setup. Do you guys know if this combo will fit? rims are 18x8 front and 18x9 rear. tires are 245 in front and 275 in rear. Offset is 31mm front and 35mm rear.
anybody have any knowledge on this... would appreciate it greatly.
thanks for your time!
Aj
Anyone have
Aj
Anyone have
2 SL with every Brabus mods available & Class A competition sound system
fit what.....?? an SL......??
if that your question......no it will not fit an SL.....due to the high offset......
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
ahh, yes, sorry for the confusion, but yes, its for a 91' SL500.
Would the wheel stick out too far or ....???
thanks SL Brabus!
Aj
thanks SL Brabus!
Aj
thanks SL Brabus, i'll look into that as well.. would longer lug screws be required as well? thank you again...
Aj
Aj
They'll fit just fine. The width of your front rims is the same as what your friend has now, and the offset is nearly identical. On the rear, pretty much the same, except that your rims will extend both inward and outward an additional half-inch.
I know what I just wrote contradicts another response, but if you or your friend eyeball what he has now and visualize, then you will see I am right.
Use the same lug bolts.
99 SL Sport
i basically got the same response from the other benz forum. the only way we will know for sure is to simply bolt them on. i think we will do that here shortly if he does want to follow thru and buy.
Again, thank you both...
Aj
Aj
