SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Car Won't Downshift At Highway Speeds (Delay in Acceleration)
Old Jan 21, 2007 | 11:14 PM
HLG600's Avatar
2009 SL63 AMG
Exclamation Car Won't Downshift At Highway Speeds (Delay in Acceleration)
Driving to meet up with a friend and these two girls last night, figured I'd have some fun on the open highway. Travelling at roughly 60 mph when I floored to kickdown. The revs went up, but the car did not acclerate anywhere near the expected punch. Tried once more, same deal. Engine revved, but the 5SP didn't downshift.
I dropped it into 3rd gear, 3/4 throttle, and wow did the car move. Shifted to 4th, with the grin on my face getting bigger.
So, why do think the auto didn't downshift when floored to kickdown? I did a transmission computer reset today...slightly better result, but still an annoying delay in WOT acceleration (auto mode). I use the gears, the V12 hammers away.
Any idea about the source of this newfound acceleration delay?
Old Jan 21, 2007 | 11:29 PM
Bigdot's Avatar
some
hows teh tranny fluid is it fresh? was the tranny cold?
Old Jan 22, 2007 | 02:33 AM
99_SL_Sport's Avatar
Your kickdown switch is obviously bad.
Old Jan 22, 2007 | 05:23 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Actually, this can't be a possibility. The kickdown switch does not influence 5th-4th gear downshifts on the '96 and later SL600.
The problem may relate to the throttle position signal that the transmission control unit receives over the controller network from the engine control module. I think it is best evaluated by a shop that has access to Mercedes diagnostic scan tools like the HHT or SDS.
Old Jan 22, 2007 | 01:49 PM
jjay911's Avatar
1991 300sl 5 speed manual
you just need one of these...
Attached Thumbnails Car Won't Downshift At Highway Speeds (Delay in Acceleration)-100_0616.jpg   Car Won't Downshift At Highway Speeds (Delay in Acceleration)-100_0615.jpg
Old Jan 22, 2007 | 03:07 PM
bobterry99's Avatar
Good luck in convincing anyone of that, because I have one that I would love to sell.
Old Jan 22, 2007 | 05:10 PM
jjay911's Avatar
Tell us about it.. WHy.. JJ
Old Jan 22, 2007 | 09:15 PM
HLG600's Avatar
2009 SL63 AMG
The engine temperature was at 80-85 degrees celcius, maybe 15 minutes of moderate driving in cold weather. To my knowledge, the transmission fluid hasn't been changed. Since the car has only 43,000 miles, I don't plan on changing it until 70K, hopefully. Drove it today in automatic mode, and acceleration seemed fine (didn't go WOT due to traffic restrictions, but plan to test it out again this weekend). On a side note, I love shifting the car myself: 40 mph, downshift to 2nd, and you can feel the torque really pull.
When I get the chance, I am going to reset the transmission computer again, and take it on the highway right after. I am hoping it is just a glitch after driving in traffic alot.
Old Jan 22, 2007 | 10:09 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
Check if there any leak on the tranny...... Hope this help....... good luck.....
Old Jan 22, 2007 | 10:30 PM
How could a leak possibly cause the kickdown not to work? The transmission shifts down fine with the lever and when the car slows down.
Old Jan 22, 2007 | 11:03 PM
SL BRABUS's Avatar
The transmission will not shifts properly if the fluid is low or over fill when it in auto ........
Old Jan 23, 2007 | 01:00 PM
I agree, but since the car shifts fine with the lever and speed changes, doesn't that rule out the possibility that the fluid level is the cause?
Old Jan 23, 2007 | 11:41 PM
SL BRABUS's Avatar
Yes, I know what you mean....... But it don't hurt to check it out.........
Old Jan 24, 2007 | 11:07 PM
HLG600's Avatar
2009 SL63 AMG
Thanks for the input guys.
Floored it to kickdown again today. This time, there was a one second delay in throttle followed by an onslaught of acceleration and the conquering of a hill at 80 mph. However, I have yet to reset the transmission computer again. It now appears to be just a glitch that needed a heavy foot to correct.
Old Jan 24, 2007 | 11:20 PM
SL BRABUS's Avatar
I think your V12 is jealous at you because you been thinking about those 2 girls instead of your car.....
Old Jan 25, 2007 | 02:35 AM
SL600 V12's Avatar
Our transmissions are self learning no? Maybe it just got used to not doing kickdown or doing slow kickdown from city driving.
Old Jan 25, 2007 | 07:24 AM
bobterry99's Avatar
Yes, the electronically-controlled transmission learns the style of the driver and adapts its shift characteristics, but this does not affect shifts at full throttle.
Old Jan 25, 2007 | 08:13 PM
damaged's Avatar
Enterprise rent-a-car!!!
Since when is the kick down switch not used for kick down ???
You could have a few problems here. Fluid level is not an issue, as the transmission would shift but it would slip.
It could be a bad selector switch, kick down switch, valve body, or one of the solenoid valves in the electrical plate.
First thing to check is the floor mat. Has it curled up under throttle pedal and stopping you getting kick down??. If not have it put on an sds and have codes pulled and go from there.
Good luck
Old Jan 26, 2007 | 05:14 AM
bobterry99's Avatar
jjay911: I'm dumping my manual tranny '90 300SL and other R129s because I have too many cars, and there is no place to put them.
You misunderstood. I did not write that the switch is not used for kickdown. I simply noted a circumstance where beyond full throttle, engaging the switch had no bearing on what gear the transmission would shift to. This is unconditionally true for the 5-4 shift on the SL500 and SL600. In contrast, it does matter on the SL320: at high speeds the 5-4 shift will only occur if the kickdown switch is engaged.
That is all moot in HLG's case, actually. Given that he was going 60 MPH when he floored the gas, upon seeing full throttle the tranny ECU should have downshifted to 3rd gear, and once again, whether or not the kickdown switch were engaged would be irrelevant.
Old Jan 30, 2007 | 04:06 PM
jjay911's Avatar
I have storage. How much??? I want to do a project car 129 sl manual trany with a C36 engine.. What do you think of that??? JJ
Old Jan 30, 2007 | 09:34 PM
bobterry99's Avatar
I'm thinking I want about $9K for the car. If you are interested and want more info, email me and I will reply with pictures and more info about the car.
