SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Need HELP! 91 SL
Old May 12, 2007 | 03:02 PM
91 300SL Stick's Avatar
1991 300SL 5 speed manual, 90 Acura Legend Cpe, 97 LR Defender 90, 08 Range Rover, 89 Range Rover
Need HELP! 91 SL
As I am driving my car and I use the turn signals, ALL of the warning lights on the dash light up and the radio cuts off for a second. At first, it only happened once and a while, but now it happens on a regular basis. Now, it looks like the problem has progressed...some times the car completely cuts off when I hit the brakes...It happened last night, and I could not get the car re-started for about a min...Thanks in advance for any advise
Old May 12, 2007 | 10:33 PM
bicylindrico's Avatar
I saw something like this about three times in the past. The lights would flash just as you hit the turn signal. I replaced the clusters for the repair. I actually still have two in my toolbox I used as testers. The w140 and w129 were interchangable. I don't remember an issue with the radio though.
I am not sure about your running issue.
Old May 13, 2007 | 09:51 AM
Thanks...I will check the cluster...glad to know the w140 is the same cluster...
Old May 13, 2007 | 04:02 PM
jjay911's Avatar
1991 300sl 5 speed manual
Keep us posted..
Old May 14, 2007 | 07:25 PM
o_Anapodos...'s Avatar
300sl R129 Lotec turbo, 300sel 6.3 w109
I had the same problem and i changed a fuse (inside the front hood) and the broblem solved! I got terriffed when all the warning lights turned on... reminded me the ''knight rider''
replace the fuses! Start from that easy to do it yourself and cheap! Hope this helped!
Old May 15, 2007 | 02:51 PM
Nitti's Avatar
Thanks for your help on this, I have a 91 500 sl as well in South Africa and mine does the same thing....very worrying. I iwll change the fuses and check back with you guys
Old May 15, 2007 | 08:34 PM
Thanks...I will check the fuses ASAP...I will keep everyone updated...
Old May 16, 2007 | 12:38 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
The problem with the dash lights may be a faulty capacitor on the instrument cluster circuit board. It is easy to replace, and the procedure has been successfully done by me and many others. See this thread: http://www.benzworld.org/forums/r129...question.html?
Old May 22, 2007 | 03:48 PM
Thanks bobterry99, I will also check the capacitor...the picture in the link is great...do I have to solder any connectors?
Old Nov 24, 2007 | 09:25 AM
Tgor's Avatar
1992 SL-300
I have learned.....
I have learned, from experience, that when I have a problem with the electrical system in the car to replace the fuses first. They may not look bad but the original fuses were aluminum which reacted with the copper connections to cause corroding. You can now find copper replacement fuses at some auto stores. Good luck!
