SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: '93 600SL. 18' AMG's - Terrible inside tire wear
Old Oct 24, 2007 | 11:55 AM
jasonnquinn's Avatar
'93 W129 600SL - White 18' AMG Staggerd
Just had new tires put on when I purchased the car this April. 18' AMG staggered wheels - 10,000 miles later I lose air in one of the tires..notice terrible inside wear on the rear tires..some on the front as well. What could be the issue?
Old Oct 24, 2007 | 08:55 PM
Just Some Guy's Avatar
1997 SL500, 1994 Impala SS on steroids, 2007 MV Agusta Brutale 910R
your camber setting is off, who ever aligned your car didnt do the job, they just set the toe.
Old Oct 25, 2007 | 10:09 AM
Good word..I'm going today to get new tires and an alignment done.
Old Oct 25, 2007 | 11:42 AM
jjay911's Avatar
1991 300sl 5 speed manual
You may need more than that. IF its real bad maybe a camber kit for the rear. JJ
Old Oct 25, 2007 | 12:27 PM
Bigdot's Avatar
some
it is my understading that none makes a camber for the 129.
plus doesn't the 600 have ADS?
Mark
Old Oct 25, 2007 | 12:28 PM
+1
Old Oct 25, 2007 | 12:30 PM
Mark
Kmac makes a kit, i have it on the front of my car
Old Oct 27, 2007 | 03:20 AM
jjay911's Avatar
I have a buddy that can install them. Im selling my car but Im putting a camber kit on my Sedan because I blew threw 2000 dollars worth of tires on the SL in 2 years 24,000 miles...
Old Oct 29, 2007 | 11:51 PM
Hisrange's Avatar
'93 600SL
I went to Tire Pros..and was told I was bad off of alignment. We'll see.
Old Oct 31, 2007 | 02:27 PM
jjay911's Avatar
An allignment will help a bit but what you have is too much negative camber.
Old Oct 31, 2007 | 05:27 PM
assuming the car isnt bent or sagging, the camber adjustment is part of a proper alignment, although most places just set the toe and dont touch anything else. This is one of my complaints about MB, they build a rock solid powertrain, but the front end engineering is just plain retarded.
