SL/R129: 95 500SL with possible ignition problem
Sometimes the Benz runs great. Then again, sometimes it will backfire while cranking and will never start. Once it backfires, it will not start, however, I can go back and try again in several hours or overnight and it will start right up.
Then again, there are times when I will be driving and will pull up to a stop sign or a red light and the car will die in place. In this case, I am forced to push the car off of the road because it will not start again. However, I can go back several hours later or overnight and it starts right up.
I have taken the car to a local shop (the closest MB dealer is 65 miles) with a great reputation. They told me that the cats were poisoned and needed to be replaced. They did not do a computer scan of the engine because they said their equipment would not read the 95 or 96 models? They made the recommendation based on the sweet/gas smell in the car after running it. So I purchased two cats on the internet and had them installed.....and the car wouldn't start at all. That was yesterday and I went back today and the car started right up.....go figure.
What am I missing here? Does anybody have any experience with this kind of behavior? What else can I try? I am a new MB owner and I sure would appreciate you folks sharing some of your experiences with me.
Thanks for your consideration.
Boyd Hogan
95 500SL
63 TBird
Suffolk, VA
http://www.benzworld.org/forums/r-c1...roblems-2.html
We'll see what I can find.
I think Lee is quite correct about having the codes read either at a dealer or better independent tech that invested in the MB Star Diagnostics system. Having said that, from what you're describing and the MY of the car, my inclination would be to inspect the engine wiring harness as the mid 90's MY's had known difficulties with wiring/insulation degradation. The start/stall/no start/cool down/start symptom sounds to me like the crankshaft position sensor at the rear of the engine. When these fail, the fuel pump is shut down, fuel pressure is lost and the car stalls. When the engines cool somewhat, they will often start again, but you're on borrowed time.
Last, find a new indy who has a better sense of smell. This is the first I've heard that clogged cats smell sweet. It could be true, I've just never heard that 'diagnostic'.
Bob
