SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: '97 SL600 possible power steering fluid leak ?
Old Dec 27, 2009 | 04:02 PM
tunnelvision's Avatar
'97 SL600 Triple Black
I believe the slow leak I see dripping on the floor of my garage is from the power steering...however...no apparent/obvious means to check fluid level. Can someone please advise...or is it a closed system...or is the hydraulic fluid one in the same...I know it isn't oil.
Thanks for any feedback
Old Dec 28, 2009 | 04:02 PM
SL-ML-C's Avatar
2000 MR-S daily driver, 1997 SL600 weekend fun, 1999 ML430 tow vehicle
I would wager that it is actually coming from one of you ADS hydropneumatic bladders actually.
Old Dec 28, 2009 | 04:44 PM
Hi SL-ML-C,
Thank you very much for the response. Sounds probable...troubleshooting has comenced...I'll update...I found a couple of very loose high pressure hose clamps that had to be tightened appropriately. I hope that was it. Now it's time to troubleshoot from the bottom.
OT: Would the fluid, having saturated the belt, likely cause the belt to be at risk of breaking or weakening? Is there a safe method of cleaning without ruining the integrity of the rubber? If you have no answer that is ok...thank you for your initital response.
Tunnelvision
Old Dec 30, 2009 | 02:42 PM
SL-ML-C's Avatar
when this happened to my ADS accumulator 3 years ago, I just replaced the accumulator and filled er' back up with hyraulycoil and changed nothing else.
my belt has been fine ever since.
Old Dec 30, 2009 | 03:33 PM
Hydraulic Fluid Leak - ADS
The fluid leak is hydraulic...the odds move into your favor, regarding your previous wager. I've narrowed the source to rear of the Power steering pump assy. Next step is thorough cleaning for obvious reasons
MB dealer parts man indicated the power steering pump has dual function...kind of like business up front and party in the back. Brakes in front/ADS in back...I guess I'll buy it until I conclude otherwise.
tunnelvision
