SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Rear View Mirror - 1998 SL 500
Old May 21, 2012 | 01:58 PM
BrewCrew's Avatar
SL 500
As other owners of the SL500 I have a wobbly and loose rear view mirror. Can anyone point me in the right direction to buy a used one. Thank you.
Old May 22, 2012 | 08:20 AM
BJonesFL's Avatar
'87 560SL Sold, '99 SL500 For Keeps
Are you looking for a used one because yours is damaged and can't be repaired?
Old May 22, 2012 | 09:39 AM
BrewCrew's Avatar
SL 500
Yes, any help would be much appreciated - thanks
Old Jun 1, 2012 | 02:58 PM
Baybear's Avatar
2012 SLS AMG Roadster
If it's just loose you should be able to remove it, take it apart and tighten the nut on the stem. This solved my wobbly mirror problem.
Baybear
Old Jun 2, 2012 | 08:26 AM
degeja's Avatar
2016 E350 Sedan SPort
bewareca on ebay has wrecked cars he sells parts from- if he hasn,t listed one, email him for what you need. Other ebay sellers also periodcially sell the mirrors.
yes, tightening the nut on the swivel works if that's the only problem-sometimes the inside plastic retainers break and the mirror itself is loose inside the housing.-- takes longer but can be repaired.
remove mirror to access nut on back after prying apart the mirror housing-- be careful-as the plastic retainers break easily- I pry from the side with a screwdriver-- its a break away attachment for safety-- snaps back in.
each year model an be different from earlier/later years in addition to color.
Old Jun 2, 2012 | 08:46 AM
degeja's Avatar
http://stores.ebay.com/BAWARECA-bargainAUTOparts?_rdc=1
email him if yours isn't listed
Old Jul 7, 2015 | 09:04 AM
jeffimac's Avatar
1998 Mercedes SL500
1998 Mercedes SL 500 rearview mirror
I too have a problem with my inside rear view mirror. Someone at one time took the mirror apart and the 2 spring steel bands are missing. Would anyone have a mirror they've taken apart for whatever reason and kept any of the internal parts. Thanks, Jeff
Old Jul 7, 2015 | 10:14 PM
rojacobs1's Avatar
'96 SL500 Sport
Mine was wobbling so I opened it up. Tried to tightened the nut down as much as I could and it still wobbled. I realized that the nut was not going to tighten down any further on the threaded stem, so I used a garden hose washer (believe it or not) underneath the nut (I just split the washer to get it on). It worked great!
Old Jul 8, 2015 | 09:12 PM
sutliffe's Avatar
1998 SL500
Just do it!
Simple fix. Did it myself in ten minutes!
