- Mercedes Benz C Class Why "Performance Chips" Don't Work
Guide to diagnose trouble and recommended solutions
Browse all: Engine Diagnostics
SL/R129: Bolt on Performance kits - electric superchargers and performance chips
Has anyone installed the performance kits bolt on - like GForce performance chips and electric superchargers from the following vendors or simillar;
1) http://www.superchargertuning.com/Mercedes-Benz/SL/
2) http://www.gforcechips.com/mercedessl600.aspx
I want to try this upgrade, but would like to know if it's really worth the money invested, before I commit to this investment. Please help to enlighten from point of technical and practicality.
thank you.
The 1994 SL600 was tuned by replacing the computer chips in the two ECU's. I bought them in 2000 and do not remember the source. I had a private Mercedes tech do it, it is more complicated than the instruction sheet makes it sound and I did not want to damage the two ECU's through my incompetence. The performance improvements were subtle but improved the feel of the car. The timing was clearly advanced throughout the entire engine map and the mixture was likely leaned out slightly. Part throttle drive ability was really improved and the engine is running cooler in 35 to 55 suburban driving. Fuel consumption decreased slightly, less than a one MPG improvement.
The other noticable change was a 400RPM reduction in the transition from the long to the short intake runners (2300 down to 1900RPM). This change is noticable and improves low RPM acceleration. I would guess the peak TQ and HP to be up at most 5%.
the two such as Brabus and RENNtech will definately be a place to go for major mods...
in view of you post - which one doesn't work? can you be more specific what technical flawed you encountered with the gforce performance chips and electric supercharger or simmillar products. valuable knowledge and experience shared would be much appreciated..
You'd get better performance gains by rigging up a CA/RAM intake. The GF chips are crap. Utter crap. They attempt to trick the ECU(s) into thinking that the air coming in is colder (read: more dense) so that the mixture becomes richer. Simply put, they do nothing but waste your money.
A real performance chip/tune will alter many of the ECU's parameters.
In reality, the GF chips may give you one or two more "horsepower" but a real performance oriented tune will give you (big differences in FI and N/A) between 10-100hp/tq. Some companies will even dyno-tune your car and reflash the ECU's while on the dyno to acheive the best results--that gets expensive in a hurry though.
Cheers
Some really good points are made here that I can vouch for. The FI cars respond well to reflashing with big power gains, even more available when done on a Dyno.
The older NA V12 is harder to improve if it is already properly tuned and maintained. I doubt that an external chip that tricks the ECU into reading manipulated data would be worth the money. The two replacement chips I have contain a revised map and work reasonably well.
I would add that on an early V12 I would not spend any money on tuning until the engine wiring harness is replaced. All the originals will fail and prior to failure will cause intermittent problems. I think it would be best to tune those cars on a Dyno, the gains available are less and it would be desirable to maximize the improvement. Not sure how easy it would be to find a shop to tune the older SL600's.
