SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: CD Changer replacement
Old Jan 15, 2013 | 06:30 PM
Fishmonger's Avatar
2001 SL500, 2010 Traverse
Purchased a known "GOOD" used CD changer for my 2001 SL500, all connection are correct., but car will not recognize that a unit is installed.
Plugged old defective unit back in and this indicates on radio display.
Would there be a security code for the CD changer like the one for the radio?
Any suggestions? Thank you.
Old Jan 16, 2013 | 12:51 PM
chtaylor's Avatar
1992 400E, 1997 SL500, 2009 R350, 1977 Ericson 32
There is not a security code for the CD changer. You should be able to plug it in and play.
I had a similar problem with a CD changer that I bought off of eBay. The changer turned out to be defective and the seller replaced it with another unit that has been working fine ever since.
Also, is the new unit the correct one for the year and model of your head unit?
Old Jan 16, 2013 | 02:26 PM
Fishmonger's Avatar
chtaylor, thank you for your reply and info. I was having my doubt as this is the second CD changer I have bought on eBay. I'm ready to just bag it. I did buy the correct one both times P/N A002 820 7989 Model # MC3198.
(nice boat you have)
Old Jan 16, 2013 | 03:24 PM
chtaylor's Avatar
Could it be that you've received two bad units in a row?
Old Jan 16, 2013 | 03:33 PM
Fishmonger's Avatar
Must have been, I'm done with it.
I see you have a 400E, I have a set of 1995 E420 rear brake pads, if they fit, they're your, just hate to dispose of them any other way.
Old Jan 16, 2013 | 03:39 PM
Fishmonger's Avatar
The brake pad P/N 555 2722/0 or T1014 or D525P Mfg. Pagid
chtaylor's Avatar
Thanks for the offer and for the compliment on the boat! I too have an extra set of rear pads for the 400e. I bought front and rear but my mechanic told me only the fronts needed replacing. Perhaps another member could use them.
Charles
Old Feb 22, 2013 | 12:20 PM
edcarls's Avatar
97R129-01W163-94E320-93500E
Originally Posted by Fishmonger
... I'm done with it...
Give it one more try. Connect the CD changer to your Head Unit and turn it on then disconnect and re-connect the power supply plug on the Head unit. (Be sure you have your radio code on hand.) This would reboot the HU and recognize the CD changer. Also, if you don't want to pull out your head unit you can disconnect and re-connect your battery terminal. But, you have to re-sync all affected systems.
I had similar experience. Bought a new changer and it didn't work. I tried the re-boot procedure and it worked. I tried the procedure on my original changer which I taught was dead and it worked.
Hope it works for you.
Old Feb 22, 2013 | 02:28 PM
Fishmonger's Avatar
I will give it try, you're getting my hopes up. Thank you for the feedback. R129 weather coming up and I'm ready to enjoy it.
