SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: What is....
Old Jun 14, 2015 | 04:45 PM
rojacobs1's Avatar
'96 SL500 Sport
What is....
this port/connector/plug shown in the pic(small,black,round near battery)? Nothing in the owners manual about it.
Old Jun 14, 2015 | 10:49 PM
cliffyk's Avatar
1998 SL500
It's not stock, probably an input jack for a battery maintenance charger ("battery tender", "trickle charger", etc.)...
Old Jun 15, 2015 | 07:30 AM
rojacobs1's Avatar
'96 SL500 Sport
Could be, but too small? It's only about half the diameter of a typical cigarette lighter port.
Might not mean anything though. If this is a trickle charger port, it just might be brand specific. The configuration inside the port looks like something you would see for a blade style light bulb(although more heavy duty) and not a cigarette lighter. The wiring behind it does look pretty stock though.
Old Jun 15, 2015 | 09:22 AM
cliffyk's Avatar
1998 SL500
It does not have to be a cigar lighter socket¹ to be a battery minder connection--could be anything if it was a custom install.
It is definitely not factory stock, could be some dealer installed thing.
Where does the wiring go?
¹ - The day the auto industry decided to use the cigar lighter socket as the auxiliary power standard was a dark day in electrical engineering history
Old Jun 15, 2015 | 10:33 AM
dbldpr's Avatar
Veteran: Navy
I have a charger that you plug into a cigarette lighter socket that will Charge power tools for me. It may be for something like that.
Old Jun 15, 2015 | 10:34 AM
dbldpr's Avatar
Veteran: Navy
The charger also charges my wireless printer
Old Jun 15, 2015 | 11:34 AM
cliffyk's Avatar
1998 SL500
The OP stated it is not a cigar lighter socket...
Old Jun 15, 2015 | 11:47 AM
dbldpr's Avatar
Veteran: Navy
I forgot to mention that my adaptor has a big socket and a small socket. I have never used the small socket. I only have used the big socket. Sorry I did not mention that
Old Jun 15, 2015 | 05:00 PM
rojacobs1's Avatar
'96 SL500 Sport
Traced the wires. Yup - it's for a trickle charger. Too bad it doesn't work with the one I have.
Thanks for all the input folks.
Old Jun 15, 2015 | 06:41 PM
cliffyk's Avatar
1998 SL500
Could be a power port for something too, as suggested by dbldpr...
Old Jun 16, 2015 | 03:50 PM
sutliffe's Avatar
1998 SL500
Replace connector
Just buy a connector that fits into what you have already installed. It should not be hard to find the right connector via mail order or Radio Shack if you can find one. Just be sure to connect positive to positive and negative to negative. It's a nice thing to have!
