SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1994 sl500 charging system
Old Jul 13, 2017 | 07:43 PM
SLman61's Avatar
Sl500
Hello,I have a SL500 I was driving it home and went to pass a truck going 50 mph.I dropped shifter into 2nd like I always do and as it took off I put it up into drive I was doing about 80 and as I backed off accelerator the car shut off a solid red light came on as it stalled on me.I pulled over and restarted the car and it ran fine..But I noticed the battery light is on now.The car never got hot or drove funny after it shut off.I got home and shut it off and waited 5 min restarted car it started fine but battery light is still on.Anyone have any ideas what is wrong??
Thanks in advance..
Old Jul 14, 2017 | 12:05 AM
Lee Wireless's Avatar
1995 SL500 - 2017 AMG GLC 43
Sounds like you blew fuse #9.
Old Jul 14, 2017 | 01:09 AM
SLman61's Avatar
Sl500
Ok Great I hope that's all it is.I'll check in morning..
Thanks so much for the help.
Old Jul 14, 2017 | 03:52 PM
SLman61's Avatar
Sl500
Charging system
I checked fuse and all fuses under hood non are blown ..unless there is one somewhere else.
I checked volts at battery when car running its only at 11 v so alternator isn't putting out.
Old Jul 14, 2017 | 09:15 PM
You can easily pull your voltage regulator to see if it failed.
Or just buy a rebuilt regulator.
Your choice. I had both issues.
Blown fuse and bad regulator in my 1995.
https://mbworld.org/forums/sl-class-...placement.html
Old Jul 15, 2017 | 01:06 PM
SLman61's Avatar
Sl500
So since no fueses are blown.The only other thing it could be is regulator? No inline fueses to worry about?
Old Jul 15, 2017 | 03:56 PM
No, you could have blown a diode in the Alternator. From all that I've read, 75% of the time it's the voltage regulator. The regulator solved my issue. You don't have to remove the alternator from the vehicle to change it. Do remove the negative battery terminal before starting. You'll have to remove the belt from the pulley and remove one bolt to rotate the alternator to easily remove and replace the black plastic cover on the back of the alternator.
Old Jul 18, 2017 | 12:43 AM
SLman61's Avatar
Sl500
Charging system
Thanks for info.I just ordered a regulator since that's the least expensive to start with so I'll know soon and post it
Old Aug 9, 2017 | 04:59 PM
SLman61's Avatar
Sl500
Sl500 charging system
Hey I replaced the regulator like you said how to do.
Took me an hour not bad..Still no charge and bat light is still on
Old Aug 10, 2017 | 11:27 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by SLman61
Hey I replaced the regulator...Still no charge and bat light is still on
You likely have a bad diode in the alternator. To test that you use a multimeter that has a diode testing feature, and you take measurements between the alternator case and its B+ and D+ terminals with wires disconnected from those terminals. With the (-) lead of the meter is on the case and the (+) lead on a terminal you would expect an open circuit; with the leads reversed you would expect to measure a voltage of around .8 volts.
