SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL600 ADS
Old Apr 14, 2019 | 11:04 AM
Fabio D's Avatar
210 55
SL600 ADS
Hello members! anyone with a very hard noisy sls rear suspention? What to look?
Fabio D.
Old Apr 16, 2019 | 05:57 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
I don't believe a component associated with ADS could be the cause of the noisy suspension. A bushing in one of the links or control arms could be, however.
Old Apr 23, 2019 | 08:57 PM
Fabio D's Avatar
210 55
talk about ADS cause is common in the w140 and w124 with self leveling suspensión start to make major noise the stuts itself and need to be replaced. Anyone with the same in the 129s with self leveling in the rear or ads?
the car was very confortable and soft. But horrible noisy rear suspension at irregular pavment
thanks in advance
Fabio D.
Old Apr 24, 2019 | 08:10 AM
bobterry99's Avatar
There are no struts in the rear of any R129. There are shock absorbers, and they are similar to a standard shock except there is a hose attached which connects the shock to an external vessel (nitrogen sphere) which acts as an air spring.
I've never known a shock absorber to make a sound of any kind.
Old Apr 25, 2019 | 03:56 PM
AndreasHannover's Avatar
SL600
Hallo,
The lower joint of the shock absorber can creak when there are bumps on he road. Very annoying, i replaced both.
Regards
Andreas
Old May 2, 2019 | 09:57 PM
Fabio D's Avatar
210 55
Originally Posted by AndreasHannover
Hallo,
Regards
Andreas
Thanks my friend! Thats what im thinking about. The noise comes from the shock absorbers. I have the car in the shop changing water pump, belt, repair the soft top leak and this noise. Pretty sure the noise are related to the shocks. You find the lower joints separatly? Or just replace the whole shock
thanks in advance
Fabio D.
Old May 3, 2019 | 05:15 AM
SL600
I did not found one, but here, the cost of one shock absorber surprisely is not as expensive as expected, something around 300 Euro.
Old May 3, 2019 | 09:01 AM
Fabio D's Avatar
210 55
Many thanks Andreas!! I will inspect the shocks and joints and i update!!
Fabio D.
