SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Engine Mount Replacement
Old Sep 29, 2020 | 09:51 PM
ChrisB's Avatar
1999 SL 500 & 2011 E 550 4Matic
About 50,000 Km ago - a MB Shop recommended I replace the engine mounts on my 1999 SL500 which had 200,000 Km on it at the time.
An independent mechs is said - not needed. So I did nothing.
Still going fine - when do mounts need to be replaced?
Old Sep 29, 2020 | 11:06 PM
mahunt's Avatar
1997 MB SL600
Chances are that the mounts have collapsed by now.
They collapse naturally in time even if the car sits, but even more so in usage.
Old Sep 30, 2020 | 03:22 AM
rideair's Avatar
1990 300se, 1980 450sl
I have a 1997 with 86,000 miles (138,000KM) and they were replaced this week.
Found sitting at a stop-light, there would be a slight vibration.
FYI, normally you replace the engine/trans mounts at the same time.
Old Nov 17, 2020 | 09:32 PM
hanscan's Avatar
1996 SL500,2014 GLK 350
Open the hood, start the car, watch the engine at short and quick power .
If the engine does not pop up left and right, your good.
When the mounts start weeping its time to weep.
Old Jan 27, 2021 | 09:34 PM
ChrisB's Avatar
The mechanic I go to took a look & confirmed the motor mounts are collapsed.
How many other R-129 owners have replaced motor & transmission mounts?
If not replaced by now ... they would all be collapsed.
Does it really make any difference?
I do not want to continue to put undue stress on drive train - if that is what might be happening.
I do not experience vibrations or noises (that I have not become accustomed to anyway) ... so will replacing mounts at the advanced mileage really do much?
Old Jan 28, 2021 | 10:35 AM
AndreasHannover's Avatar
SL600
Shure, there are big differences. And the engine is lower than normal and the hose of the radiator rubs at some other parts.
