SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: CEL-PO441 purge flow incorrect
Old May 31, 2021 | 01:14 PM
hanscan's Avatar
1996 SL500,2014 GLK 350
CEL- PO441 at half fuel tank only every time, erased code stays off.
Fuel cap is new, evap. solenoid works.
Old Aug 9, 2021 | 10:56 AM
bhesse's Avatar
1997 SL500
Just had mine come on at half tank, but I think I may not have screwed cap on all the way to click
Old Aug 10, 2021 | 09:27 AM
FATHERTIME's Avatar
94 SL320 98 SL500 99 SL600 07 SL55
Check vacuum line coming from charcoal tank and valve for charcoal bits if so install inline fuel filter.
Old Aug 10, 2021 | 03:35 PM
mahunt's Avatar
1997 MB SL600
I like the inline fuel filter idea, because the upstream purge valves do get clogged with the charcoal granules over time.
Old Aug 12, 2021 | 12:43 AM
FATHERTIME's Avatar
By all means check this first before buying that way over priced valve, clean it out with Brake cleaning spray and actuate it with a couple wires clipped to the battery till you can't blow through it when it's closed.
Old Aug 12, 2021 | 01:54 AM
hanscan's Avatar
Thanks Guys for all the advices.
But the CEL comes on at halve tank only.
If i top off the fuel before the half point, it's all good, no CEL
Old Aug 12, 2021 | 02:55 AM
FATHERTIME's Avatar
Vacuum leak
Old Aug 12, 2021 | 03:03 PM
hanscan's Avatar
Vacuum leak be constant
