SL/R129: 2002 Silver Arrow build thread
Installed all new rebuilt top hydraulics from Tophydraclis. Cleaned the rear window also, came out really well, using Plastic X.
Lowering it with Vogtland 35mm springs.
Also waiting to install adjustable upper camber mounts on the front shocks and I have rear camber arms also.
You are going to swap out the SA rims? If you do, sell them as they are quite rare and desirable.
You have to get the overall tire diameter correct on your new rim and tire combo so that the ABS and cruise control will work.
NA 5.4 swap
Cat delete, custom exhaust
211 e63 front calipers and cl55 rear calipers
150% valve body
all black interior
black window moldings
Suede or alcanata headliner in the hard top, and pillars
new soft top
I am sure I will do more, just can’t think of it at this time.
Bro, this car has 143,000 miles, I paid 7k for it. I don’t care how rare it is. It’s getting modified a lot! I took a dump this morning, and it was super rare, but I still flushed it down the toilet!
I fitted a Wiechers carbon strut bar, but I had no idea about the Ultra Racing braces. Is there any reason these won't fit a 600? Unless someone can confirm they won't work...I'm ordering em.
Sorry, just saw this. Yes is should fit a 600. They are the same. Your car already has the two braces in the rear, it just tied them together.
Front wheels showed up last week.
thanks!
18x9 25 front and 18x10 32 rear. Will run a 255/40, and 285/35 or a 295/35 still not sure yet.
waiting on this customer to shop up in his w212 e63 m156 car with the factory 18s, they are the same specs on the front wheels, and tire size
