SL/R129: Suspension Options 2022 Recommendations
Before I ask the question I will confirm that I searched the threads to look at which options are best for a upgrade for the suspension (shocks and lowering springs) but most of the posts are over 10 years old and as a result a lot of parts and options are no longer available.
Does anyone have a 2022 recommendation for a suspension upgrade on 2001 SL500?
Thanks in advance!
I can't see why the H&Rs would not work since the springs should be the same from 1990-2001 unless I'm wrong.
Any advice?
Any advice?
If you are going to go struts/shocks and springs, you might as well rebuild the front end (A-arms, tie rods, that kind of stuff) and the rear (carrier bearing, links, sway bar bushings, etc.)
Oh, and if you lower the car that much there is a teensy slight small possibility that the front bumper might rip off the car if you are in the habit of braille parking the car. ADS optioned cars just toggle the rocker UP and kick back for about 30 seconds while the car lifts.
BC was also an incredible pain in the *** to deal with from a warranty standpoint over here in Europe. They refused warranty replacement without me mailing the originals back to them because there was no visible damage or leak from the outside of the damper, so I had to pay for replacements out of pocket. They also are located in the UK, which is no longer a part of the EU, so I had to pay a 35% tax on those replacements in order to import them to Germany, where I live. Those taxes could be avoided if they shipped via DHL, as I am an American and technically exempt, but only DHL has provision to avoid the fees available. The replacements they sent then failed in the same manner in less than 2 weeks, and they again refused replacement, and also refused reimbursement for taxes incurred should they actually agree to warranty them after mailing them back.
I was not about to pay for yet another pair of likely faulty dampers out of pocket, plus no-refundable taxes, so I made the decision to move on from them as a brand.
Currently working on a full custom setup based on Ohlins dampers. Fronts are good, but rear has been a little more problematic difficult due to lack of space. My engineer also ran into an issue with a lack of decent help after his second got recalled to active military duty due to the Ukraine war and is in the heat of the Nürburgring season where the majority of his business comes form. Hoping to have it completely sorted soon.
Has anyone else had this happen? Did my mechanic miss a spacer or something when installing?
Count the notches and verify that the right one was used, but it sure sounds like you need a pair of thicker front spacers.
You know, notches in the shims. As in, #1 front shim #3 rear buffer.
Sounds like you need maybe a 2 notch spacer for the front springs.
The spacer is located at the top of the spring and the notches are visible by looking. A single notch is denoted by two protrusions, a double by three, etc.
I've seen them called a number of things - tabs, protrusions, burls. First time I've heard of 'notches' between the 'tabs.'
Please correct me if I'm wrong.
