SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: R 129 Coolant Temp Question
Old Aug 23, 2022 | 06:04 PM
kwelch02's Avatar
1996 sl 500
I have a 97 SL 500. 106k
My Coolant gauge shows a reading of between 80 and just under 100c at the top end. This is on expressway or surface streets with AC on and outside temps in the 80s.
Is this a normal range?
I have had new hoses, belt and pulleys and new coolant in the last few months. I believe the clutch may be original, but not sure.
If this is too high, where should I be looking?
Thanks.
Old Aug 23, 2022 | 10:46 PM
mahunt's Avatar
1997 MB SL600
That's perfect.
Figure 100C as 212F and you are probably right at 195F. Perfect for an aluminum engine.
Old Aug 24, 2022 | 07:01 AM
kwelch02's Avatar
1996 sl 500
Thank You!
Old Aug 25, 2022 | 03:28 AM
Ahmed's Avatar
R129 SL55 AMG & W208 CLK55 AMG
What exactly do you mean by that? Is the needle actually oscillating from 80 to "just under 100" repetitively?
Old Aug 25, 2022 | 05:33 AM
kwelch02's Avatar
1996 sl 500
No, it does not bounce around at all. Just climbs to just under 100c
Old Aug 25, 2022 | 08:02 AM
AndreasHannover's Avatar
SL600
That's too much for normal conditions. Can you stop the cooler blower with a rolled newspaper when the engine is hot? If so, the clutch is dry.
Old Aug 27, 2022 | 03:20 AM
Ahmed's Avatar
It should not climb. The thermo's job is to stop it from doing that.
Old Aug 27, 2022 | 07:32 AM
kwelch02's Avatar
1996 sl 500
I did the newspaper test and the fan stops easily when hot. I have ordered a new clutch.
Old Aug 27, 2022 | 06:40 PM
Sparrow141's Avatar
A45
I drive a lot of new model MB, typically less than 5,000km, and noticed that 90 degree when cruising is quite common.
Old Aug 28, 2022 | 01:51 AM
SL600
All newer cars dont show the real temperatur. As long as the real temperatur is within a range, it shows always the same. At the R129 which showas the realy temperatur, a M119 should be behave like you can see at the picture above.
