SL/R129: In need of driveshaft center support rubber mount for SL600
Any help or knowledge of a different part number that will work is appreciated.
Doesn't the installed one get destroyed when you try to remove it and the incorporated bearing from the driveshaft?
I think I got mine from AutohausAZ.
I just looked at the price for new flex discs, $260 ugh.
any idea of another part number that works? This part isn’t available anywhere in the world as far as I know
I've gotten some pretty rare replacement parts in the recent past.
One of the tricks is they list the car as VOR (vehicle off road) and leave the parts request open for a few months. Dealerships all over the world view the request and sometimes someone somewhere rechecks their inventory and the part shows up. That's OK if the part you need is a driver's side secondary air pump hose or front ADS II pipe seal as it transitions from the wheel well to the engine compartment. But, if the vehicle is truly off road, that's not so good.
You might have to scavenge one from a junk yard and hope for the best.
And yes the rubber is a one time application part, very hard to press in. I tried to freeze the bearing and could push it in 3/4 of the way. Later a press tool was used to go all the way.
So you want to replace the two in pairs. Make sure you have a new bearing handy when you do source the support. I think there is also a third ring piece, make sure you have that too.
I believe that comes with the bearing.
My flex discs need replacing (right side of the picture) and I was rummaging through one of my parts boxes and found a few nice items.
Bearing support 1404100781
Bearing for the support 0089814325
Driveshaft centering bearings 1244100732 and 1244101032 (rear and front?)
Cautionary tale. The pile of green dust in the unopened bag is a transmission grommet like the one the the left.
I'm showing the parts in order to let folks know about the different number for the bearing support. This bearing support might not work on our cars because I either ordered it wrong or it was mis-sent. Or I though I needed it and didn't. Who knows, it might be good. Either way, I will be pulling the driveshaft sometime in the near future to change the flex discs and will take a look at the installed bearing support.
I'll report back to this thread and let everyone know if this is a good alternate number for the 1997 SL600 cars.
I don't know why I have 3 driveshaft end centering bearings, maybe because they are too hard to replace and I didn't install them.
I'm not exactly lazy, but I will only work so hard on a particular repair.
For example the only "non" dealer part I have in the car is a Febi belt tensioner, made in Germany. It looks like a high quality replacement but the center hole was misprocessed and a bit small for the bolt to go thru.
So I drilled it wider and it is fine. Their ignition lock tumbler is absolutely garbage. It was already loose brand new, and lasted 5 years, and replaced by the Mercedes one. The original had lasted 20+ years, 150K miles.
I assume a failure of the center support will have catastrophic results.
Certainly it is great to have the part numbers.
My 2 cents worth....
hello! can you let use know if that part number fit for the center bearing support?
any ways, I used an Anchor branded center support from rock auto. It comes with the bearing already pressed into it: https://www.rockauto.com/en/catalog/...+bearing,12743
Acvording to this dealership parts site, 140 410 07 81 doesn’t fit SL600s: https://www.mercedesbenz.parts/oem-p...ing-1404100781
