SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
Roof problem
Old Dec 26, 2023 | 07:18 PM
eddier's Avatar
1991 500sl
Roof problem
1991 500sl
went to put roof down windows won’t come down to start the sequence
I can put windows down using window switches and roof sequence will start when I hit button
any suggestions
thanks
Old Dec 27, 2023 | 07:56 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to R129 forum...
Old Dec 27, 2023 | 08:22 PM
Summit54's Avatar
2002 MB silver Arrow
Sequence
Here’s what I rely on when top seems to be acting goofy. Are you familiar? Ignore hand written notes.
Old Dec 28, 2023 | 03:24 AM
eddier's Avatar
1991 500sl
Step 2
So when I hit the soft top button the roll bar goes down but the windows do not
it proceeds to do steps 3 , 4 and 5 and than it stops
will not go beyond that unless I lower the windows by the window switches
Old Dec 28, 2023 | 05:15 AM
Summit54's Avatar
I probably should have asked if you have reset your window cycle. If not, I would do that next. At the same time, lower windows all the way and hold for 5 seconds, then raise all the way and hold for 5 seconds. This should get your windows back in sync (if windows are closed and you open door, they will drop..etc)
after reset, try the cycle again.
with the charts and steps provided, you can isolate the switch that maybe bad.
Old Dec 28, 2023 | 05:42 AM
eddier's Avatar
1991 500sl
Soft top
Yes tried to reset window switches
no luck
