SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: No dash lights, won’t start
Old May 27, 2024 | 05:41 PM
Bcron's Avatar
500SL
Need some starting help. 1991 sl500 won’t start when dash lights aren’t present. When I turn the key forward, if I have dash lights, it starts fine. If no dash lights, it cranks and cranks but won’t kick over. I was thinking fuel pump relay? It sometimes runs rough at idle which I’ve read is also a symptom of fuel pump relay. I’ve read conflicting info on location of the relay. It’s a 119.155 engine.
Old May 28, 2024 | 11:54 PM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
Sounds like you have some ignition switch issues. Rough idle is probably unrelated and not a fuel pump relay issue. Rough idle can have many culprits, fuel pump relay must be at the bottom of that list as I have never seen that come up for a rough idle.
Old Aug 28, 2025 | 09:37 AM
Adeleio's Avatar
1990 500sl
Did you ever sort this out? I am having the identical problem. I am in a 1990.
Old Aug 28, 2025 | 09:49 AM
Bcron's Avatar
500SL
Yes. It was in fact the ignition switch. I replaced it myself. There are a couple of good videos out there I used as guidance. I consider myself as “moderately” inclined mechanically and it wasn’t a real hard job, I think I spent maybe an hour on it.
Old Aug 28, 2025 | 12:06 PM
Adeleio's Avatar
1990 500sl
That's great info...thanks for the reply. Very helpful indeed.
Old Aug 28, 2025 | 04:59 PM
Bcron's Avatar
500SL
Good luck! Just take it slowly. There’s a part in there that can’t be broken in the process or you’ll be royally screwed. The videos address it.
Old Sep 1, 2025 | 03:41 PM
2Jags's Avatar
1999 SL500 Sport w/Pano, 2007 Jaguar XKR, 2009 Jaguar XJ Super V8 Portfolo
Is the battery fully charged? Greater than 12.6v after resting overnight?
Old Sep 1, 2025 | 04:13 PM
Bcron's Avatar
500SL
It was the ignition switch.
Old Sep 1, 2025 | 04:26 PM
dolucasi's Avatar
And you also had some rough idle issues. How is that coming along?
Old Sep 2, 2025 | 07:54 AM
Bcron's Avatar
500SL
I’ve determined it’s a fuel issue. When I take it out of storage in the spring, I experience the occasional rougher idle on the old gas (even though I add StaBil before storage). Once I burn off that tank and refill with fresh gas, it pretty much disappears.
Old Sep 3, 2025 | 06:38 AM
dolucasi's Avatar
Yes, I am the original owner of my '89 W201. Also have the '88. Both cars like to be used a few times a month. The more you use them to better they run.
Sitting for months on end was never good for my W201.
- Cheers!
