SL/R129: Whats up with those rear-view mirrors ?
But the previous owner seems to have loved to hang off the rear-view mirror. Whatever cheap piece of plastic is internal to the darn thing is broken, and the mirror flops all over the place.
I spoke to my mechanic - who told me to deal with it, since a replacement is like $850 !!! So whats up with this badly designed expensive piece of engineering ? Evidently its a common problem ?
Secondly - anyone know of an aftermarket replacement ? I believe I saw an SL with a radar detector built into the rear-view mirror once - i've scoured the internet to no avail - but I wouldn't mind putting out a few dollars for something that is actually worth the money. In the meantime, wads of dollar bills are keeping the mirror relatively stable (!)
I cured the looseness with a rubber seal around the post, where it attaches to the top of the mirror.
Later, I found that moving the electric adjustment forward (for mirror up) and backward (for mirror down) slowly, took the play out of the mirror! It was never like new, but it no longer flopped around. Good luck. rg
I have repaired two of these mirrors. In one case, the broken plastic tab was loose in the mirror, and I simply epoxied it back into place. But with the other broken mirror it was gone. In that case I straightened the end of the clip (the end is bent 90-degrees to engage the plastic tab), heated it with a soldering iron, and pushed it into the plastic where the retaining tab had broken so that it was anchored in the frame. If you were to take yours apart, then I think you would see what I mean.
HTH,
Phil
1994 SL500
I have the same problem with my 97, I just stuck a dime in between. it doesn't fix it, but it makes it a little better. I have yet to remove it and investigate to try and come up with a solution.
Driving back from San Diego, the first thing that I noticed was a wobbly rearview. After seeing this thread a day or two later, I figured that it would just be a problem that I would have to live with or attempt one of the fixes above.
I tore into it today and found only that the large nut in the base next to the spring loaded mounting lugs (through which all of the small wires go) was just ever so slightly loose. Tightened it up and all is well. None of the plastic parts or tabs appear to be broken.
Other than cracks in the plastic mounts for the visors, and cracks in the plastic cover around the rearview assy, I have yet to find a single thing broken or not functioning in this great car. Not too bad for 10 years old. Not to mention that it is a blast and pure pleasure to drive.
I have a 96 SL500 with the same problem...except for MY model year, athough it does NOT have the electric motor running it...it DOES have the red ball (for the remote locking-unlocking gizmo) on it...and I would need to be VERY careful with it. Can you describe how it dis-assembles please?
I just got done replacing one of the bulbs in my third-brake light array on the trunk...what a nasty job THAT was! I'm STILL bleeding!
