SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Manifold gasket replacement problems
Old Jun 14, 2025 | 08:38 PM
adaco's Avatar
I am the original owner of my R129. It has always been well run and maintained. It has just undergone the replacement of the intake manifold gasket by a reputable, experienced shop, Following completion, the engine will accept some throttle in park/neutral. With the transmission in gear, and load on the engine at operating temperature, the engine will not accept throttle.The engine stalls and backfires through the intake. When attempting to restart, backfiring occurs through intake or exhaust. The engine light does not come on during these issues. Any suggestions that might not have been tried already?
Old Jun 15, 2025 | 12:28 AM
mahunt's Avatar
1997 MB SL600
Do you have any idea if the car has 6, 8 or 12 cylinders?
Or even the year?
Old Jun 15, 2025 | 09:40 AM
adaco's Avatar
Sl/R129 Manifold gasket replacement problems
Or even the year?
Yes I am the original owner of the vehicle. It is a 1990 500 SL with 8 cylinders.
Old Jun 15, 2025 | 12:09 PM
dolucasi's Avatar
190E 2.6L 1989, 190E 2.6L 1988, BMW 535dXdrive 2014, BMW 428i 2015
Backfire thru intake generally means ignition is not happening in one or more cylinders. So you have developed an ignition problem. Most likely the mechanic messed up something during the manifold gasket work. I would start looking at ignition related issues, distributor cap, rotor, spark plug wiring (order maybe wrong), etc. etc.
