SL/R129: MBZ 600SL 1996-1998
Thank you all in advance.
https://www.benzworld.org/threads/be...06338/#replies
Read that and then follow the link on post #26 for a little more.
I'm not a fan of the jerks on the other site.
The R129 is a legendary platform and I've been enjoying the nostalgia.
MY1997 and 1998 have historically been regarded as the peak years for the R129.
My former SL600 was a 1997 model, the build quality of that car left an impression that is clear even to this day.
All that said, if I were to get back into an R129, a 1999-2002 SL500 with the factory Sport package and Xenon headlights would be a strong contender.
-Generally better track record with the M113 over the M119 as both platforms have aged.
-The M120 V12, despite being one of the best and most stout engines ever built, is comparatively limited today by parts being much harder to source than for the M113.
-Same goes for ADS, which is why a R129 that was factory-designed for a strut / shock / spring suspension setup will be less risky to own.
I did just swap out the front ADSII spheres (4th time) and had to go with genuine MB parts shipped from der Fatherland and a bit more expensive than the regular Corteco stuff. Hopefully, they will last the usual 7 years.
My power steering low pressure return hose also got soft and expired with the only parts available coming from Germany.
I'm still getting factory parts for the car from MB which is pretty amazing considering that the car is almost 30 years old. I can't imagine what a mechanic would charge to do the maintenance, IF you could find someone you trusted.
I wouldn't be able to do the maintenance the car needs if it were one of the later SL cars.
Definitely, if you aren't a VERY competent mechanic with a little cash and patience, I would NOT recommend owing one of the V12 cars. It's not like owning or taking care of a Toyota.
They are a challenge, but also rewarding.
After 4 years of ownership I have had to clean the contacts on the back of the cluster to clear up a finicky gas gauge. I changed all fluids first. And I had the hood repainted.
Again, I can not thank you all enough for your input.....Thank you.
I probably wouldn't want a car with unusually low miles that has sat most of its life unused (especially a SL600). There are MANY systems in the car that need regular exercise to stay healthy. But, this is more a philosophy for me, not a universal truth for others. You would be the one owning and taking care of the car, get what you think best.
I once read that the engine isn't really considered broken in until about 200K miles; that might be true.
The front "shocks" (the rear ones too for that matter) are hydraulic rams. They don't absorb anything, they just set the ride height. Also, if they don't leak; they're good. I haven't really heard of a front ADS strut going bad, but I suppose it happens. All the "give" in the suspension comes from the hydraulic spheres and the action/performance of the suspension comes from the ADS valves located near each sphere. All of this is controlled by the ADS computer in the electronics box under the hood. The springs don't even hold up the car (the front struts and rear "shocks" do that) , they just damp road oscillations.
I would think you could replace all 4 spheres (yourself) for about $1K. I just did my front spheres (with dealership parts) and that was $700, the rears are about $300 a pair. Oh, and the ZHM oil is about $25 a quart at the dealership, figure about 2 quarts for each side. About the only thing that goes wrong with ADSII cars are the spheres. They seem to last about 6-7 years whether you drive the car or not. I did have to replace 2 capacitors on the ADS computer board, but everybody will have that repair in their future. Not very hard to do and I added to another members writeup awhile ago.
Unfortunately, I don't have the space or knowledge to DIY. That's why I vetted many mechanics and landed on one that I can trust. So, mileage-wise. Purchasing a 600SL at 80k-120k would be the norm?
I own an R129 V12 and an R230 V12, both in excellent condition. If I had to choose, the R230 would leave the fleet in less than a second.
So please elaborate on why you own both an R129 and R230 V12 and would dump the 230 so quickly. In my case I should clarify that I dont care for the v12s as they put way more weight on the front end . They also guzzle fuel and really cram the engine bay, making things more difficult to get to. The v8s are way more than powerful enough and you get 50/50 weight balance with the 550.
I realize this is the R129 forum and i do think they are excellent autos. Certainly a moon shot compared to the older SLs and waaay ahead of their time. But time marches on and I do personally feel the R230 was an improvement in many ways.
Ultimately buying any old Benz is a dice roll and I am sorry the OP rolled a snake eyes with his 2007. My point stands though- once you sort any of them, they should provide reliable motoring for many years to come. Why start all over again with an even older starting point?
You're correct. If and when I make the change, I'll go back to the BMW Z4-M or the 2006 E46 M3. Although if I can find a well-cared-for 2007-2008 SL 55 AMG.....who knows at this point.
The myth about the top-heavy V12 is everywhere; in fact, the weight distribution, at least in the R129, is quite balanced, roughly 52% to 48% front to rear. I haven't weighed the R230 yet, but the ABC suspension ensures good roadholding there anyway. I occasionally drive it on a racetrack, and the handling is extremely forgiving. All SLs are far too heavy for serious use.
Sure, the R230 does everything better than the R129, but it looks like all the other cars. The decision for or against a car is a matter of taste, and I don't like new cars. I bought the R230 because I'm curious about its technology. If it were gone, I wouldn't miss it.
Oh, and you really can not compare a V12 against any other engines, its like a Rolex compare to a Timex.
