SL/R129: Lower Back Pain - What to Do?
I don't want spend thousands of dollars buying new seats. Can anyone recommend a lumbar support that I can add to the existing seats? I have the standard seats - not the multicontour.
Thanks, Will
Thanks, Will
In catalogs, I've seen pads that attach to the seat and claim to support the lower back. Has anyone tried one of these to see if they work?
It's ironic that the seats in my 2002 SL500 don't feel as comfortable as the ones in my 190E. Are the seats in the newer SLs any better?
This might sound obvious but are your position adjustments ideal for your height.
http://www.businesscopiers.com/backs...aceairplus.htm
http://www.ultimatewatermassage.com/...hions-back.htm
http://www.backfitpro.com/supports.htm
http://www.backandneckpainsupplies.c...w_backrest.htm
http://www.reliefmart.com/adjustable...t_supports.htm
http://cgi.ebay.com/ws/eBayISAPI.dll...551057967&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...552868332&rd=1
etc., etc., etc.
Don
Having owned the SL for over two years now and having driven lots of 2 hour + trips. I'd say the SL is fine for a daily driver. For this type of driving we have never had any trouble at all.
However this past September we drove 1,500 miles over 4 days through the mountains in heavy rain most of the time. About 6 hours a day driving with the extra tension of driving in the wet all the time was enough to give both my wife and I lower back pain that lingered for months.
We eventually bought a new bed, box spring and matress because our sleep patterns were disrupted by the back pain to the point that we were not getting good sleep on our 10 year old bed.
Our long road trip experience was such that I guess we will never be driving from Vancouver down to San Diego and back again on the pactific coast higway
.I drove from San Fran to Boston and back to Los Angeles. A good bed stop made all the difference.
Will
Just 2 Torx screws can be removed from the rear back of the seat to release the top squab of my 92 R129 seats, may well be the same on your more recent cars. It comes out easily by pulling out the base, and I have made some simple, albeit fixed adjustments to the seat profile, by inserting something in between the wire frame and the cushion material. A couple of small pieces of wood 10-15mm thick, one each side can be jammed in to force the seat back out around the lower back. Keep adjusting till you like it.
This is still in trial with me, but certainly has improved the profile. I have found the original shape of the seats ideal for hugging grip of your body, but indeed a bit lacking in lower back support. When you push out the lower back, it feels a little less hugging of course.
I have taken care and don't believe it has in any way caused any problems with the wiring of the seat heating. It does make the Torx screws a little harder to get back in, as the wire frame springs back a bit too.
After I have got the exact shape / placement I want, I may look at instead deforming the wire support frame rather than chocking it with an insert- I think this is preferable.
Better still, you could incorporate those dynamic air ones quoted further up in this post into the seat where I put the wood!
Perhaps not. I'm 6' 1" and have the seat all the way back. The seat controls don't seem to work intuitively in this state. For example, when I try to recline the seat, it moves forward. Probably trying to avoid hitting the back. No matter how I position the seat, my lower back isn't supported.
That's alright, I expected some surprise / derision on this one!
For this technique, it needs to be very firm to push the whole thing forward from the back. Use anything firm that you like that sounds trendier, but wool won't do it as no pressure could be achieved against the wire frame.
But if those inflatable bladders are very tough, and perhaps with a firm backing, they could be the answer. Especially if you sneak the bulb out somewhere discreet so it can be adjusted in situ.
Greg
