SL/R230: ? on TIRE NUMBERS
2006 SL600, 2001 S500, 1996 SL320
? on TIRE NUMBERS
Can anyone tell me what the various numbers and letters mean on these tires??
Front Michelin Pilot Sport 255/40 ZR 18 95Y
Rear Michelin Pilot Sport 285/35 ZR 18 97Y
2001 E320 (210.065), Brilliant Silver; 2002 Ducati ST-2, Arrest-me Red
Better to post in tire & wheel forum...
But so long as I'm here...
The first number is the width of the tire in millimeters.
The two-digit number after the slash or dash (40 and 35 in your examples) is the profile or aspect ratio. Basically it's an expression of the width of one sidewall as a percentage of the tire width, so one sidewall on the first tire would be .40 x 255 or 102 mm "tall".
The letter (Z in this case) is the speed rating of the tire and the last two-digit number is the diameter of the wheel the tire is designed to fit.
You can find all this -- and more -- at tirerack.com. They have a lot of useful info there.
If you want to play with different tire widths, aspect ratios and diameters, the boys at miata.net have a great little java toy: www.miata.net/garage/tirecalc.html
Enjoy the ride,
Greg
Enjoy the ride,
Greg
2002 BMW 745Li Black/beige, 2006 SL600 Capri Blue/Black still on order
Steve
What Rad said, I wouldn't mess with going different sizes unless you can find it on Tirerack.com . I use them for almost everything except finding a date for Saturday.
I have Clublexus for that..
Check out Michelin PDF
http://www.michelinman.com/assets/pd...pilotsport.pdf
Check out the Michelin PDF, in reference to rear tires
285/35 ZR18's
Which one would you pick 97W or 97Y.
It seems on our cars you get 97Y but they lick 97W as original equipment. Does it make a difference????
285/35 ZR18's
You should be able to order the Pilots with the MO designation, this means its specs have been approved as original equipment by MB; I've been told there is no difference (who knows) but the stock tires all carry this marking and if you're a perfectionist like me, you'll want it on yours...
SL500 and A-CLASS
285/35 ZR18's
285/35 ZR18's
97 is the load index. I was depressed when Michline stop making pilotsport with a load index of 91 for my SLK. My SLK came with pilotsport with a load index of 91. The new pilotsport only supports 87. I had to get a different tire for my SLK.
The test results below are from tire tests perfrom for an hour.
W-Speed Rated Sizes:
Maximum Speed (mph).....118..124..130..136..143..149..155..161.. 168
Inflation Increase (psi)........0..1.5...3.0..4.5...6.0...7.5...7.5.. 7.5..7.5
Load Capacity (% of max).100.100..100..100..100..100....95...90...85
Y-Speed Rated Sizes:
Maximum Speed (mph)......118.124.130.136.143.149.155.161.168.174 .180.186
Inflation Increase (psi) ........0....0....0....0..1.5....3..4.5....6..7.5. 7.5..7.5.7.5
Load Capacity (% of max) 100.100.100.100.100.100.100..100.100..95..90..85
Strange
I thought it was strange that the W-rated Tires are listed as original mercedes equipment when it is actually the Y-rated tire that comes on the car with the sport package.
SL500 and A-CLASS
