SL/R230: STOPPED on RENNTECH UPGRADE - S**T
Old 08-03-2005, 06:32 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
I tried to remove the ECU this afternoon, but either I am suddenly learning impaired or my connectors are glued on.
The first connector that has to come off won't come off, I was hoping the black bank around the first one came off with it, but from what I am told that is not the case. I am told to wiggle it loose, but I don't see how that is possible when I can't even grab it.
Anyone have any ideas.
Wish I could just pay someone to take it out and not f**k with it myself. If I go to the dealer who does Renntech, they will give me a hard time on warranty which could be a hard time as it already is.
Old 08-03-2005, 06:41 PM
vraa's Avatar
That's a really good pictures..
What is glued down exactly? I'm not sure where you are trying to go.
Old 08-03-2005, 06:43 PM
StephenK's Avatar
Glued
Hopefully nothing is glued that was just my sense of frustration, I just can't get that first connector to come out. Always a SNAG!!!
Old 08-03-2005, 06:46 PM
vraa's Avatar
Do you have some needle nose pliers you can try to use to wiggle it out?
Old 08-03-2005, 06:51 PM
LovinMercedes's Avatar
2023 760i and 2023 EQS580V4
Exclamation This is how you do it...
This is a standard Mercedes Benz locked plug. In order to remove this plug take the band across the top and slide it down the side and it will release automatically.
Old 08-03-2005, 06:55 PM
vraa's Avatar
Duh, when you push in the clip?
Old 08-03-2005, 07:33 PM
Exclamation Further detail...
Before you release the plug you need to release the housing. To do this you need to push in from the outside on the tab on the top of the wires on the left. That will release the housing around the plug. Then you push the tab on the plug and the band will be free to move all the way down to release the plug.
Old 08-03-2005, 08:27 PM
lorinserbenz's Avatar
none
What lovin said.. its a slide thing... very easy to remove
Old 08-03-2005, 08:30 PM
StephenK's Avatar
I am totally missing this one I don't get it.
I am totally missing this one.
I don't get it.
Old 08-03-2005, 09:05 PM
vraa's Avatar
Old 08-03-2005, 09:22 PM
StephenK's Avatar
Ricky
Thanks Ricky, but I think you are combining two connectors into one step. Look at Renntech's site
Goto Renntechmercedes.com
Then click the instructions tab and then ECU Removal.
Old 08-03-2005, 09:54 PM
vraa's Avatar
I think I see what you're talking about. I guess I photoshopped according to the wrong piece.
Try this.
I think it's me, but I'm having the time of my life trying to help you man, this is fun!
Old 08-04-2005, 02:14 AM
midget fidger's Avatar
E550 Coupe
hahaha it's always fun reading what you write on pictures or screenshots
Old 08-04-2005, 07:38 AM
sillydriver's Avatar
SL600, A8L W12, Continental GT, Range Rover SC
Stephenk,
As I mentioned in other comments, the biggest problem with the upgrade is having to do it yourself. I did it successfully, but then I always built my home computer out of parts for fun, so I’m not put off by oddball connectors. The problem here is that the computer you are having difficulties with is the easy one. The tough one – or at least I thought it was the tough one – is the transmission unit behind the passenger-side footwell carpet. Maybe I just had a hard time because the bracket was a little warped, but the TCU involved some straining and skinned knuckles while I thought the ECU was a snap.
My point is that if you are having trouble with the ECU, you might consider having a professional do the job. An internet search (or even the yellow pages) should uncover a shop specialized in performance modifications for European cars. Even if they focus on Porsches and BMWs, they should have technicians comfortable with kind of procedures in Renntech’s instructions. Or perhaps Renntech can recommend someone in the Tallahassee area.
If you do decide to go ahead by yourself, I suggest that before you unplug the connectors, you label them with tape marked to remind you which one goes where on reassembly. Also, if any of the steps seem non-intuitive, jot a note to yourself so you can reverse the procedure later on. Good luck.
Old 08-04-2005, 03:12 PM
StephenK's Avatar
Solution
Think I got a good solution. DerekFSU referred me to a friend of his who is a MB Mechanic, he is going to come over and get these two parts out for me. That's a relief!
Old 08-04-2005, 04:21 PM
vraa's Avatar
Make sure you take pictures and if you can, videos. I want to see how to do it as well!
Old 08-04-2005, 04:32 PM
deuce zer0's Avatar
E63
i enjoyed the read. Thanks
Old 08-07-2005, 10:16 PM
vraa's Avatar
So uhm, have you gotten it done yet?
Old 08-07-2005, 10:19 PM
StephenK's Avatar
Not Yet
I only need $6,399.00 more dollars Care to help me??
Old 08-07-2005, 10:20 PM
vraa's Avatar
I can help you by shaving some dollars off that price
Old 08-07-2005, 10:26 PM
StephenK's Avatar
How
How
Old 08-07-2005, 10:32 PM
vraa's Avatar
I'm a RENNtech dealer!
Old 08-08-2005, 08:51 PM
Florida Chris's Avatar
SL65 AMG
OK, would you mind PMing me your price for the ECU upgrade on my SL65? Thanks!
Old 08-08-2005, 09:49 PM
StephenK's Avatar
Sending off Tomorrow
How would it work thru you, sending it off tomorrow one way or the other.
Old 08-08-2005, 10:47 PM
vraa's Avatar
Since the RENNtech ECU for these cars is a big ticket upgrade, I go ahead and bump you up to my boss, Neal. Just tell them I told you to contact him directly and he'll give you major priority and service.
You can contact him at info@euroteckmotorsports.com
Stephen: Basically we become the middleman to take care of anything. Just like when you buy a Mercedes, except in the case with the Mercedes, you are limited to buying it only through MB USA. They are pretty much the LOCKED middleman.
Florida Chris: Just follow the instructions above. Sicne it's one of those bigger ticket items, we'd like to make sure our customers are taken care of 110% of the way
Quick Reply: SL/R230: STOPPED on RENNTECH UPGRADE - S**T
