SL/R230: Tire pressure monitors
Old Feb 2, 2006 | 05:45 PM
ChrisSL's Avatar
New wheels, new sensors - BERU from Tirerack, drove the car for 5 minutes - still same message - like the values will show up / will be displayed after a couple of minutes of driving - so, should i drive it more than 5 minutes or take it to the dealer to reset the computer ??? thx.
Old Feb 27, 2006 | 03:23 PM
ChrisSL's Avatar
I still have problems with the tire pressure monitors - today finally I drove the car for 30 minutes and still no reading out of the monitors although I activated the reading 3-4 times
Wheels ANTERA (designed to accomodate tire pressure monitors)
sensors BERU 315mhz transmitter and Beru 49mm long valve stem
At least i do NOT get the message " Tire pressure monitors not found "
So, any help here ? thx.
Old Feb 27, 2006 | 04:05 PM
ChrisSL's Avatar
Very useful links
http://www.beru.com/download/produkt...rung_tss_e.pdf
http://www.beru.com/download/produkt...tung_tss_e.pdf
Old Mar 8, 2006 | 10:14 PM
rellik's Avatar
mercedes
did you ever figure them out, i have the same issue
Old Mar 8, 2006 | 11:21 PM
ChrisSL's Avatar
the car is at the dealer/service dept to have the problem fixed - i'll post here the results
Old Mar 22, 2006 | 12:30 AM
ChrisSL's Avatar
Problem solved - Tire rack sent wrong sensors - on the invoice they were 315 mhz sensors but in fact they were 433 mhz ( european specs ) - i got the 315 mhz and had them installed at the dealer - but ... red message - INACTIVE - this problem solved,too - the guys left the other sensors in the trunk so there were 8 sensors total - everything works fine now
Old Mar 22, 2006 | 12:59 PM
jonnyml500's Avatar
05' SL500 (Sold) - 01' S430 - 05' Yama R1- 02' ML500 (sold)
Curious why couldn't they use your oem sensors. For my rims they just removed the stem where the sensors were embedded and plugged it in the new rims. i did not have any problems with it.
Old Mar 22, 2006 | 04:54 PM
ChrisSL's Avatar
i'm planning to keep the OEM wheels for 2 reasons - 1.winter 2. in case of any ABC / SBC problem they have no reason to blame the aftermarket wheels
