SL/R230: What OIL?
Does anyone know what type to use?????
Mobil 1 0w-40 european formula.
You can get it at most good parts stores.
It will say mercedes 229.5 spec on the back of the bottle.
How would you say you've been driving it, easy, medium, hard, or out of control?
I live in South Florida and go to Renntech for my oil changes. The only oil they will put in my 2005 SL600 is Mobil 1 15W 50. I asked them about the recommended grades of 5 or 10w 40 and they told me the 15w 50 will protect the car the best. It probably doesn't make a huge difference since I change my oil every 5000 - 6000 miles but they seem to be pretty adamant about it. I guess if you are riding the car hard, thicker oil should be better. JMO.
Larry
http://www.whnet.com/4x4/oil.html
You can use anything that's 229.5 or 229.51 spec.
https://www.fleet.ford.com/FFH/Rental05_23_06.asp
they might be recomending 15 over 0 because its south
FL. The weather is alot warmer and humid here, so its
easier to get away with a thicker oil. In the north where
its cold, you dont want to use as thick of an oil, as it will
take a little while to lubricate all the parts from a cold
start. Atleast this is what my personal mechanic has taught
me.
