SL/R230: Couple of questions on 07 SL550
I looked but am either blind or didn't look hard enough to find the answer, so I turn to you experts to help.
1. Should something more than the steering wheel going up happen when I turn on entry/exit ease. I would have thought the seat should go back also.
2. Should the right hand mirror tilt down when in reverse and backing up? I don't see a setting and when I select the right mirror and back up nothing happens.
3. Shouldn't the headrest go Up and down with the power switch on the door. Mine only goes up and I have to push down manually.
Thanks guys
Thanks guys
07 SL550; C32 (sold)
Thanks guys
Thanks guys
2. they took that functionality off. advisor told me depending on the production date, some had the function.
3. it should go up and down.
07 SL55, 1954 Corvette, 09 E350
I'll have to think about 1 and 3 but I think they are a function of how you selected memory.
As far as passenger mirror in reverse - you need to select the passenger mirror (push the button down and leave it down all the time) then when you go into reverse the passenger mirror will tilt down.
My Service Advisor Kim showed me this trick. She is great.
2007 SL550
Hope you are enjoying your '07 SL550. I love mine. I have had it for almost a year. Ironically the only problem I have had is with the headrest. I had to have the motor in the passenger headrest replaced as it would go up but not down. It was no big deal - nothing else got wrecked when they replaced it.
I too wish the seat would go back when you stop the car in the '07. Unfortunately MB got sued because someone was injured in a previous model when the went back. Now, only the wheel goes up. I had to have the instrument cluster replaced in an '05 that I had and lost that function with the new cluster. That really sucked.
The '07 SL550 is an awesome car though huh? Let's see some pics!
I wonder if a software update would bring it back?
head rest sl550
on my 2007 sl550, how can i remove the drivers side headrest? i have a bad neck, and am able to do it on practically every other car brand. thank you
Thanks guys[/QUOTE]
Thanks guys[/QUOTE]
bmw M3 Convertible, SL550 AMG
Need to hold memory seat button
My 07 SL550 have none of the features you mentioned(1, 2, 3). In addition, my memory seat button need to press and hold till the seat , mirror etc move to presetted position. I will think you should only need to press the button once. It just very inconvenient. Does it happen to everybody else as well?
