SL/R230: Retrofit DVD Comand in to 2003 SL?
Old May 6, 2007 | 08:39 PM
whozurdaddy's Avatar
Is it possible to replace a 2003 CD based Comand unit with a DVD based unit from a 2005 SL? I read somewhere about the wiring being different (HOST?) but I was wondering if anyone had adapted it.
Old May 6, 2007 | 10:52 PM
SUNILP's Avatar
2015 E250D
it can be done, expensive, and it's MOST.
Old May 6, 2007 | 10:58 PM
Thanks Sunil. Do you have any info on this? Who could do it? How much it would cost?
Thanks!
Old May 7, 2007 | 07:08 AM
SUNILP's Avatar
2015 E250D
I have done a similar upgrade on my C class. There is no telling what the cost will be until you start the upgrade. A couple grand atleast.
Old May 7, 2007 | 07:20 AM
theboogers's Avatar
2020 S560,14 ml350, 03 sl55, silver, pano, slr cams, evo headers, lsd, 2019 s63 cab.
i would be interested in this also, but replace command means replacing wiring and trim surround also? keep talking about this.
Old May 7, 2007 | 08:54 PM
SUNILP's Avatar
2015 E250D
Here is the link about my upgrade. http://web.mac.com/motorwerks/iWeb/S...934C6FF7B.html It may not be so complicated on a SL but one never knows. As a minimum, you will require a comand, wood panel, amp, wiring harness, fiber optic harness. Then you can add a changer, voice control, phone system, etc... at a later date. Your current cluster may not display the audio info as well. I have not looked into the parts catalog as no one that I know has been serious enough to do the upgrade... or I have told them to get a newer SL instead.
