SL/R230: Tail Light DIY simplified
Old May 28, 2009 | 05:47 AM
vincesgfv's Avatar
SL 500 SP & C 280
[quote]
Originally Posted by oofreakoo
Vincesgfb - I havent had time to install the center light yet but you're tempting me to stop by the stealer on the way home. If I do get one I will install this weekend and post it up.
THANK FOR YOUR TIME TO LOOK INTO IT BUT I INSTALLED IT ALREADY AND IT EASIER THAN THE TAIL LAMP.
Old May 29, 2009 | 11:11 AM
oofreakoo's Avatar
2003 SL500, Lamborghini Gallardo
So where's your write up???? j/k
Old May 30, 2009 | 03:44 AM
vincesgfv's Avatar
SL 500 SP & C 280
I WILL POST IT SOON.
MY 07+ SL 65 TAIL LIGHT & TOP BRAKE LIGHT
Old May 31, 2009 | 06:48 PM
fnaylor's Avatar
2005 SL500
DIY 2007 AMG SL55 Tail Lights
I also would like to thank you for taking the time to detail the steps necessary in completing this upgrade. After reading your post and DIY instructions, I decided to purchase a set of SL55 AMG tail lights for my SL500. Enclosed is a pic of my car pre new tail lights.
Frank
Old Jun 2, 2009 | 02:47 PM
tnguyenmdc's Avatar
2004 SL500 & 2008 GL450
If you could please post instruction on how to replace the third brake light, I would really appreciate it. I've been waiting to learn how to do it, so I can replace all the rear lights at the same time.
Thank you,
Old Jun 5, 2009 | 03:45 AM
vincesgfv's Avatar
SL 500 SP & C 280
THIS IS HOW I DID MY, THERE ARE MAYBE OTHERS WAY TO DO IT, BUT I FIND THIS WAY IS EASY AND FAST TOO..
1 UNCREW THESE ^^^
A (top) I USE A SPOON TO TAKE THESE OFF
B- UNCREW BY HAND
AFTER ALL THE CREW IN THE PICS ARE OFF PULL THE CARPET DOWN THEN YOU CAN SEE THE 2 NUTS THAT HOLD THE TOP BAKE LIGHT USE 10MM WRENCH TO REMOVE THESE A 6-8" RACHET WRENCH WITH MAGNETIC HEAD IS VERY USEFUL BECAUSE THE NUT ON THE PASS. SIDE HAS LIMITED SPACE. AFTER THE NUTS ARE OFF PULL THE LIGHT FROM OUTSIDE DISCONNECT THE ELECTRIC CONNECTOR AND CONNECT THE NEW LIGHT, USE THE OLD METAL BRACKET AND PUT THING BACK IN REVERSE ORDER.
Old Jun 5, 2009 | 10:18 AM
  #32
Artyi's Avatar
Mercedes-Benz SL 500
Mine with changed lights.
I can say it makes a huge difference when you change the 3rd led light.
Recommended!
Old Jun 27, 2009 | 09:20 PM
  #33
fnaylor's Avatar
2005 SL500
New Tail Lights Installed
I got my new tail lights early this week. This morning, I installed them. I absolutely love the new look. See pic. The conversion was a bit of a challenge in some spots. "Tight fit getting the 8 mm deep well socket around the tail light posts. Another area of frustration was one of the carpet locks. In trying to remove I ended up taking the top right off the male post. I did manage to finally get it out, but a trip to the MB dealer is planned for Monday to replace.
Old Jul 31, 2009 | 05:23 PM
  #34
SPIKES's Avatar
2019 S63 COUPE
got mine today and it is installed.....wow....looks great
thanks for the help on the forum.....
Old Aug 1, 2009 | 03:04 PM
  #35
playdo's Avatar
sl500
Congrats on the new lights.
In the passed 6 months I've been torn between the white or smoked lights for my white SL.
Old Jan 21, 2018 | 02:56 PM
  #36
skans's Avatar
Mercedes Sl500 2003
Changed my lights
Thought this would be useful for those wanting to switch out the tail lights from SL500 to SL55. Process takes less than 20min. This may not be the "right way" for this process but if you are strapped for time, this is for you.
Thanks to your guide I decided to change the lights on my SL500 2003 that I bought in december, found used ones from Ebay for 400 Eur.
Next order of business is to remove the AMG bage as soon as the car leaves the winter garage.
/skans
