SL/R230: 03 SL500 remote problem
Old Mar 10, 2008 | 06:53 PM
elviento's Avatar
Basically my remote stopped working. Can't close the door, can't open the door, can't open the trunk, but when I press the remote, the little red light at the rear view miorros would blink, so the remote is not entirely dead, just not working right.
So what do you think is the problem? Battery in the remote? Battery in the car? Wiring issues? Thank you for any input.
Old Mar 10, 2008 | 07:21 PM
gqa's Avatar
gqa
05' sl 500
is this the key less go card your talking about? i believe the 03's had a separate card and key
if its the key itself, will it start the car? if not i might just need reprogramming.
Old Mar 10, 2008 | 08:01 PM
ToonArmy's Avatar
2003 SL500
First check whether the other key works. If both keys stopped working, I'd suspect something in the car. If the other key still works, then the guesses would be 1) battery 2) key re-programming. Not sure if you can re-program or need the dealer - I had a new key reprogrammed by the dealer.
Old Mar 10, 2008 | 08:34 PM
elviento's Avatar
Thanks. This is the regular key (not keyless go). It WILL start the car no problem. I have been driving it lately using the metal key to get in and out.
Old Mar 10, 2008 | 08:36 PM
elviento's Avatar
That would be a great idea, except unfortunately, this is the only key I have...
Old Mar 10, 2008 | 09:26 PM
gqa's Avatar
gqa
05' sl 500
ok it sounds like your battery in the key. also when you replace it make sure the 2 contacts next to the batt stick up.
im sure you already know but you have to get a second key in case of an emergency. i.e. your 1st key completely craps out
you can get that battery at radio shack. i believe its a cr2032
Old Mar 10, 2008 | 09:40 PM
lovemysl's Avatar
SL500 2003 Designo (sold), SL500 2004, Nissan GT350
Sounds like a dead battery. However the key will start the car even with a dead battery.
Old Mar 10, 2008 | 10:09 PM
SL2003driver's Avatar
CLS63, GLK350
battery plus get another key
Old Mar 11, 2008 | 10:23 AM
elviento's Avatar
Absolutely. I will go get another key...
Old Mar 8, 2010 | 07:50 PM
j_belll's Avatar
‘23 EQS AMG
i've got the same problem now, its been acting up lately.
how simple is it to change the battery?
Old Mar 8, 2010 | 08:21 PM
mkirincic's Avatar
2003 SL500, 1998 E320 Wagon
I agree with the rest, I would try the battery key first. However, if the car can start with the key fob then it could be something else. The automatic door openers work on a vacuum pump that is located in the trunk. Can you unlock the trunk through the button inside the car? if you squeeze on the truck latch do you hear the actuator trying to open the trunk? is there an air leak?
Like I stated in the easiest thing to check is the battery, you can buy it at Lowes for less than $6.
