SL/R230: 19" rims - do any of you lower the car?
If any of you have SL's with 19's, can ya please post some pics?
Very important to fit the correct (approved) tyre for this car when fitting 19" rims. Even so, due to increased width of especially the rear rim/tyre (10"/285), it's necessary to do some very slight modifications when going to the 19" Styling IVs (shortening the bolts fixing the wheelhouse cover, and checking to see that the fender lip does not foul the tyrewall at full suspension deflection. (Both easy to perform).
But don't think of lowering the suspension. You'll be in for some major bodywork modification.
The 19" rims give the impression that they fill the wheelarches better, but it's an illusion, as the tyres are lower profile.
The IVs look good on especially the silver car. Less cluttered and glitzy than the Brabus, imho.
Regards,
Lowering the car is not just a case of hacking around with the springs. The suspension is much more complex than on a normal car and changing the ride height requires changes to the ABC controller programming. Brabus do this as part of their modifications but as well as changing the at rest ride height, they also change the points at which the car lowers itself.
those arent LMs... these are LMs
They are BBS LM's made for Inden Design.
Edit: Actually the SL above could have 20" rims, i just checked the Inden site and they DO offer a 20" setup for the R230.
THose are BBS LM's in 19" x 11" rears and 19" x 9.5" fronts. The car is lowered via an electronic lowering module that costs about 1200.00. Inden also stated that all 4 fenders required to be rolled to prevent rubbing.
-Shank
It definitely looks better to lower the car; maybe not as much as in the earlier pics, but by about 1"-1 1/2" .
Here is another option that will not void any warranties like some of the 3rd party lowering units.
Bring the car to Mercedes and tell them to lower it! I had done this on our CL500 and they lowered the car by 1" within specs. This is all done on a laptop; the ABC has an upper and lower limit and many are set towards the upper end by default.
That why you see many "same model" Mercedes look somewhat different on the ride. I was told that it can be lowered more when using the AMG software version, but never asked for that.
Depending of how nice the service manager is, this maybe covered under warranty and you pay nothing (I didn't)
Wolfman
but on my sl im gettin a sports package which comes with 18" instead of the regular 17" and there is quite enough space to put 20" but the car lowers when u reach a certain speed....i would put 19" just to be safe...nice choice on the rims have fun with ur car
im guessin the highest u can go without hittin the frame are 20"
i'd go for 19's also .. 20's seem.. well weird, i'd rather have a lower car and 17's or something
