SL/R230: Standard or Winter Mode question!!
2003 SL55, 2006 CLK500, 1998 Vette
Hello everyone. I just noticed in my manual that my SL55 aside from having Manual mode and being able to use the paddles there is a Winter and Standard mode. What is the difference between the two? Not sure which one i should be using.
Which provides a more spirited drive and which will help me more on MPG?
Thank you.
Thank you.
CL500 216
S gives you a 1st gear start, and W is a second gear start, the ratio of the changes are higher in the S mode.
W or S in reverse will give you 2 different ratio's.
In W the is a Sprag clutch,, this means that in W the car cannot roll back on a hill.
It is easier to drive the car in town in W as there is less chance of spinning the rear wheels in the wet.
Hope this helps
Hope this helps
Use
s mode unless you are in a lack of traction area snow ice mud etc.
Best mpg is attained by letting the torque multiplication of the transmission do its proper job.Move all the mass of the car off the line in 1st and progress up to the higher gearing.Driving around in W just produces more strain on the engine and is to be avoided.You know the feeling when you get on a 15 speed bike and try tp pedal off in 10th gear
ohlord
ohlord
Interesting information ohlord. Thank you. I will leave it in S mode and switch it to M mode when I feel spirited
ohlord
ohlord
CL500 216
ohlord
ohlord
Using W on icy roads or in town is great,it stops you from getting through the rear tires so quickly
2010 G55
I am leaving country for one month, do I need to do anything special to my SL500 so after 1 month nothing happen to it?
I heard cars' suspension got messed up, so it was not levelled properly after their winter storage...
1 month shouldn't be a problem at all !!!!!! you might find a dead battery that's all , but i don't think you will unless you have a old battery .
