SL/R230: Ratcheting noise at startup
I just bought my 2007 SL550 recently, but this didn't start happening until two days ago. When starting up the car in the morning, I hear a ratcheting noise -- kinda like fishing line being reeled out at high speed -- that goes on for about two seconds, then stops. From the driver seat, the noise sounds like it is coming from dead-center of the hood, near the top of the engine compartment. (It stops before I can hop out and check.)
Now, once it happened when I started the car, but once it happened before I even had the opportunity, so it may have been coincidence. (I have Keyless Go, so presumably the car was waking up before I started it.) This occurred when the outside temperature was around 47 F. It hasn't occurred when I've been at work, where I am in an underground garage that is pretty warm, so I am guessing this is a temperature-related thing, but haven't seen any similar-sounding posts here, so don't know if it is expected.
I'm guessing it is a stepper motor somewhere, but that is a total guess. Any help or direction would be appreciated.
Maybe poor electrical signals between your starter and sparkplugs. Iam guessing check your sparkplugs and sparkplugs wire?
http://www.benzworld.org/forums/w211...ml#post3207374
This is almost identical to what I am hearing, albeit for a shorter period. Thanks for the tip!
Rook
