SL/R230: AMG brakes on a 2007 SL550/AMG sport
Old Feb 10, 2010 | 02:45 PM
kkwmjw1's Avatar
SL550
This has been asked a hundred times and I've search probably every thread and still no definitive answer. What does it take to retrofit Sl55 brakes to a non amg car. I'm not talking 030 brakes just the 360mm front and 330 rears. I saw picture of Erichen? car SL500 with sl55 brakes so someone has done it. Most of the threads say there in the process of doing it but then there's never any outcome. I assume (big mistake) that the caliper mounting points are different or bigger so probably new steering Knuckles and the rears does that mean new hub carriers. I know Brembo has GT kit and may go that route but i got to believe all Brembo calipers are the same basically and not model specific, it just comes down to mounting bracket being model specific. What does every one think?
Thanks for any and all responsesSince AMG brakes are made by Brembo and the caliper is separate from the mounting bracket on the front anyway, what about a mounting bracket from a Brembo kit for a Sl550 (would they even sell just the mounting bracket?) and bolt that to the Sl55 caliper and then mounting that to the steering knuckle.
Mike
Last edited by kkwmjw1; Feb 10, 2010 at 03:05 PM. Reason: started thinking(thats scary)
Old Feb 12, 2010 | 08:28 AM
Justmercedes's Avatar
06 Sl 65 AMG and CLS 350 AMG Sport pack
I did it to my 2006 sl500 but it will cost U money and time plus U need to made a custom spacer for you wheels.
Old Feb 12, 2010 | 11:08 AM
mkirincic's Avatar
2003 SL500, 1998 E320 Wagon
Can you elaborate on the modifications. If you have any pictures of the mods.
Old Feb 12, 2010 | 05:25 PM
kkwmjw1's Avatar
SL550
I'm assuming you can get around the spacer issue with the right offsets or backspacing on the wheels. I'm more interested in what it took to get the calipers to work. Are we talking different steering knuckles on the front and what about the back? I understand the money part, nothing on these cars is cheap. Looking for all and any info.
Mike
Old Feb 12, 2010 | 07:19 PM
Ok do U have any email ? i'll send u a pic basically U don't have to change the steering knuckle but U also need a set of braided brake hose to support your new caliper, cause the standard hose will expand when u push really hard. What type of AMG Caliper and brake do U have right now ?
