SL/R230: anyone know how to reset our ecu or adaptive transmission
Old Nov 1, 2010 | 08:29 PM
StephenK's Avatar
2006 SL600, 2001 S500, 1996 SL320
Do you really notice a difference???
Old Nov 1, 2010 | 10:00 PM
GET TUBED's Avatar
2004 R230 Sl500
Absolutely , but try it for yourself and report back .
Old Nov 2, 2010 | 06:51 PM
aaforever's Avatar
W221 S600 // R230 SL500 // B8 A4 // JZZ30 SC300
Does this work for 03 sl500s too? I want to try! Lol
Old Nov 2, 2010 | 09:14 PM
ohlord's Avatar
Yes it will
work for your 2003 it will work on any model with fly by wire controlled throttle and 722.6 5speed electronically controlled trans or 722.9 7 speed,
Almost every model since 1998
And no it can't be set as the default since it is part of the transmissions TCU adaptive learning process. That doesn't mean you can't perform it once a week if desired but if you drive it briskly enough to want to do it once a week your transmission is never going to be in sedate mode anyway
Ten seconds works better than 5 and wait 5 minutes to drive it or the readapt might not set.
Also to make sure of readapt make sure the door is closed and radio is off when you perform it.
Old Nov 16, 2010 | 01:33 PM
david boston's Avatar
E200 Kompressor (01)
Talking soft reset worked a charm
following the ....
Turn the ignition key to the on (not start) position.
Press the gas pedal to the floor and hold for five seconds.
Turn the key to the "off" position (don't remove the key), then release the gas pedal.
Wait at least two minutes for ECU to reset.
after 2 mins exactly from turning the key to the off position you can hear a click from behind the steering binnacle.
I prefer to shift higher up so this worked a treat.
I had a ball of codes in the ECU with limp home mode etc,
changed the tranny electrical connector, ATF had wicked up into the ECU, took it out and cleaned it off with electrical contact cleaner.
before doing the soft reset the car wouldn't engage from park, had to do the pen in the gap trick to get the solenoid to release and then when i went out of D couldn't get back to R or P without turning off.
soft reset sorted all that including the solenoid bit.
I had pulled the shifter mechanism out and took it down to it's boards, hit it with contact cleaner as well. it was filthy down there, the previous owner must have been a pig. you could see where fluid had stained up the concertina cover and the board itself.
happy,
d.
Old Oct 15, 2011 | 09:02 PM
mbslowner's Avatar
2003 SL500 AMG Package, 2015 C300, 2016 WRX
Does reset ECU harm anything if you don't do it right?
Old Oct 17, 2011 | 01:48 PM
  #32
PavementPounder's Avatar
2004 SL600, 2006 Range Rover SC
<sigh> I don't know that I'm doing this correctly. I didn't notice the external temperature do anything when I re-started. Maybe I drive too conservatively, lol.
One thing I found confusing about this thread is whether taking your foot off the pedal was actually the last step. You have to hold it down while waiting the minimum of 5 seconds before turning off the key and continue holding it down for the minimum of 2 minutes before pulling the key out?
Old Oct 17, 2011 | 05:46 PM
  #33
Television's Avatar
CL500 216
This is all an old wives tale,,,, yes the gearbox talks to the engine, but the box only has a very tiny memory,,, so you are in a hurry and using kickdown, then the box will adapt to this,,you hit a 30 limit area and you slow down and within a very short time the box is back to a more leisurely change..
You can check this out easily, enter a free way accelerating hard and engage CC and the car will change down on up hills to maintain that speed. Enter the free way slowly and engage the CC and the chances are the box will not change down to re gain the set speed
Old Oct 18, 2011 | 11:39 AM
  #34
Stoofpilot's Avatar
2004 SL500
Followed the directions. What a difference!
Old Oct 18, 2011 | 11:46 AM
  #35
John CL500's Avatar
2004 CL500
Works like a Charm! Results after ECU reset:
2004 Mercedes benz CL500
Oct 8, 2011 1:06 PM
Acceleration
0-10 MPH:0.89 sec
0-20 MPH:1.86 sec
0-30 MPH:2.81 sec
0-40 MPH:3.91 sec
0-50 MPH:5.09 sec
0-60 MPH:6.53 sec
0-70 MPH:8.44 sec
Elapsed Time
60':2.64 sec@26.6 MPH
330':6.60 sec@59.0 MPH
1/8 mi:9.85 sec@74.1 MPH
1000':12.92 sec@76.9 MPH
1/4 mi:15.75 sec@76.9 MPH
Miscellaneous
Max Speed:77.9 MPH
Max Acceleration:0.88 G's
Peak Horsepower
:320 HP
Generated by Dynolicious
Sent from my iPhone
Old Oct 18, 2011 | 12:07 PM
  #36
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I actually drive fairly hard but my car hasn't kicked down on with cruise on, something about the torque in the v12 is just awesome for climbing higher grades
