SL/R230: Have Trunk Soft Close / Trunk Assist problems. Here is how to fix DIY.
I've been trying to work through a problem with my wife's R230 SL500.
After a few months of not being driven, the central locking and all usual vacuum peripherals stopped working, so I stripped the PSE pump and sure enough the impeller blades had shattered.
So no problem, I saw the motor had burnt out so I got a replacement motor and impeller and was glad to fix the PSE issues and the seats, central locking and boot soft close started working again.
However, even though the boot now shuts no problem it can only be opened by the manual key and not the remote key or the release button on the drivers side door - it's as if the vacuum to shut the boot "is" working (as i can hear it) but the release is not - i tested this by taking out the mechanical locking mechanism, and when i push the teeth they shut but I can't get them to re open unless i use force.
Any suggestions where to look? i have glued the ball bearing ports on the mechanical lock, that doesn't seem to have made any difference (thought it might be a vacuum leak.)
Does a particular part of the lock control the release?
is my problem the same or mine is hydrolics?
thank you
ben
A few things adding up....before I start the troubleshooting....first thing I noticed was the center console would not open, then noticed the top would not go down (partition warning), then noticed the trunk would not open and locks do not work. But ultimately I had to open the trunk with the valet key and now it will not "self close" suck down tight. Same on opening, it will hum but will not unlatch and open.
Is this more than likely the PUMP it self vs. the trunk latch, since all all the components seem to be effected? Or, can a leak ANYWHERE cause problems with the entire system?
I've had zero problems the last 2 plus years since I've owned the car, 31k miles currently. I have run the battery down now and again when I forget to plug in the trickle charger. So I've had those gremlins, usually cured by a long drive or just using the charger over night.
Trunk with liner and actuator removed
Close up of were actuator mounts
Actuator assembly out of the car
Close up of actuator assembly
Where I epoxied
Where I epoxied
Where I epoxied
Where I epoxied
if i just manually shut the trunk it appears that everything else keeps working. i have not yet opened the pse because the line tests brought me to complete confusion.....a short trip.
i believe all lines are supposed to hold vacuum. i have not gone after the closer mechanism yet because it seems nobody else has had the same symptoms. don't want to fix it if it ain't broke.
after taking a good look, this should only be done on the bench, and the unit quickly removes from the whole assembly....exposing all 6 of the ports. i intend to cover the whole tubes...and the equator of the hockey puck. also, i intend to degrease all surfaces with carb cleaner or something to insure stick.
i have a scheduled maintenance in 2 Sept. for many issues in the car and this one is on the list. just wanted to see if it is common or even an issue to start with!
thanks.
During research, I discovered that the W220 S Class also has a soft close mechanism. It’s not the same as the R230 as a whole, but............... the solenoid mechanism inside the S Class mechanism is identical, so it can be removed and installed into the R230 mechanism. Why is this useful? Well on UK eBay the S Class mechanism is available second hand for approx £35 from Eastern European breakers as opposed to the circa £200 that breakers are asking for the SL mechanism. So buy a complete S Class mechanism to get a relatively cheap solenoid piece to play around with.
The problem with our cars is that the soft close latch is operated by air, and if there is a leak anywhere in the system, the pump times out, and the soft close function ceases to work until the system is reset.
So, on the latch mechanism, there are 4 air ports that mercedes plugged with small ball bearings. These bb plugs work fine when the latch mechanism is new, but as the plastic around them ages, it cracks where these ball bearings are. The cracks allow air to escape, and here is the problem.
The solution is to buy some $5.00 plastic epoxy, and glue the outside of the ports and the inside of the ports shut.
You will notice some orange silicone on the latch assembly. I initially tried to use silicone gasket maker to cover the ports, but quickly found out it was not strong enough
, and the air pushed its way out. So make sure you use a strong plastic epoxy. Gorilla Glue makes a great gel (super glue) epoxy. I used it later...In the next series of photos i will show you how to resolve the problem permanently.
Attachment 383057
Attachment 383058
Attachment 383059
Attachment 383060
Attachment 383061
Attachment 383062
Attachment 383063
Attachment 383064
Attachment 383065
Attachment 383066
After you pull the latch mechanism out reset your convenience battery, push the latch clasp in 1 click, watch as the pump actuates and closes the clasp fully, and LISTEN FOR AIR ESCAPING.. When you find the air leak, begin applying the glue there, but also apply it to the other ports just in case. Be generous..
Attachment 383067
Attachment 383068
Attachment 383069
Attachment 383070
Attachment 383071
Attachment 383072
You could take your car to the dealer and pay over $300+ to have a new latch installed, or you could fix it like i did in less than 30min and for less than $5.00
gsones
Attachment 383057
Attachment 383058
Attachment 383059
Attachment 383060
Attachment 383061
Attachment 383062
Attachment 383063
Attachment 383064
Attachment 383065
Attachment 383066
Attachment 383067
Attachment 383068
Attachment 383069
Attachment 383070
Attachment 383071
Attachment 383072
gsones
1) Trunk will open using hard key - when closing the soft close does not work.
2) The Vario Roof actuator I replaced was the one directly behind the PSE pump - fluid was leaking profusely near and around the PSE pump.
3) I failed to disconnect the consumer battery before replacing the actuator - had a couple of electrical lines that I believe tie to the internal safety button for opening the trunk spark a bit - I have not checked any fuses.
4) The Key Fob will unlock the doors but will not open the trunk
5) The drivers door trunk button will not open the trunk
As I said - absolutely no resistance when pressing on the trunk handle - looking for some thinks to check hopefully in a logical order that reduces the tear apart as much as possible.
Looking for possible causes for the trunk handle to suddenly stop working - here are a few known issues I encountered during the Vario Roof Actuator Replacement:
Just to confirm: does the roof now open and close properly?
Relevant fuses you’ll find behind the right hand seat under the bottom of the box.
gsones
A link to share for this product ? Thanks
Is it possible to close manually the trunk and to open the roof automatically before to repare the mecanism ?
Offer on ebay new part :
https://www.ebay.com/itm/Trunk-Latch...e3b81ece30d9c3
The latch uses pneumatics (air from the PSE pump) to lock, unlock, and "soft close" (meaning to suck a door or trunk that is almost closed until it is fully closed).
However, there is a separate hydraulic (oil) pump used by the auto close feature, which engages when you press the red button in your trunk. The pump is located either under the battery (on a W215) or by the battery (in a W220 and I think also in the SL models), behind the passenger side trunk shielding. Remove the plastic shielding, locate pump, remove. The transparent plastic container is a reservoir, and it's probably empty. Remove and refill with oil (ATF or power steering should work). Now use the system and you'll find the leak. Either it's slow, meaning you just need to refill it, or it's gushing (probably from one of the fittings on the piston the hoses attach to. I used QuikSteel to "caulk" the fitting to stop the leak. Refill the reservoir again, and your auto-close should now be working.
