SL/R230: Anyone have sl500 Third Brake Light laying arounf?
I looked around forever trying to get a good deal on a used one. If you do find one (which is difficult), it will run $100 or so.
The edges of these brake lights are brittle, so if it hasn't been removed, it will likely crumble between the uninstall/reinstall on your own car.
Also, there is a gasket that comes with the new one, that will disintegrate when you remove the brakelight. So if you get a used one, you'll end up using RTV or sealant to attach it to your car. And if it leaks, your trunk lid (and trunk!) will end up with water in them.. not good with the sensitive electronics in there......
I gave up and bought a brand new clear one for $135 and never looked back.
Mike
