SL/R230: ABC Fluid-Change or Not
In fact, the minimum maintenance would be a rodeo and filter change. I wouldn't dump all the oil yet, without checking the color. Fresh oil is greenish in color. Whereas old, contaminated oil is dark brownish/reddish in color, sometimes with a foul smell.
Basically the rodeo mode tests to see if the ABC suspension is working within its limits. It tests for pressure and suspension height, etc. In the process, it moves the fluid around the ABC suspension system and filters it through the ABC filter. That is why a filter change is STRONGLY recommended after a rodeo mode. In fact instead of a flush, Mercedes now recommends a rodeo and a new 3 micron filter that replaces the usual 10 micron filter.
