SL/R230: ABC to Coilovers conversion: The Ultimate FAQ
Also I wonder what happens if we remove the ABC fuse? In that case will the ABC portion of the pump still pump oil or not? I wish I knew more about how this tandem pump actually works "under the hood"...
PS: Gold Element Autoworks in chat confirmed that their Sprinter pump should fit SL600/SL65 AMG. It sounds promising.
BTW why there is a separate cooling circuit for ABC fluid? Should we keep it as well if we keep the tandem pump?
Mercedes r230 coilovers abc pump recirculate search results
If you want to replace the ABC pump with a power steering-only pump, that can be done as well. V8 cars are easy, just get a PS pump for any non-ABC V8 Mercedes, making sure it has the L shaped bracket on the front. V12 cars are more complicated, but it can be done. I'm not so sure that the Sprinter pump referenced earlier would work - I think that reservoir may be a problem. I converted my car using a V8 pump with the pulley and brackets for a G65/SL65 Black Series, along with a fabricated PS pressure line section (the V8 PS-only pump output is significantly further forward compared to the tandem pump). Also had to have a tube fabricated for the pump return; the V8 pump return won't work because it points straight forward into one of the intercooler coolant lines.
The fabrication of both the PS pressure line and the return tube was pretty simple. I made a template for the PS pressure tube using thin, easily bendable brake line and took that to a local performance shop to be reproduced with 3/8" stainless (if you don't have professional tube bending equipment, don't even bother trying to work with 3/8" stainless - you WILL kink it). Materials and labor was $150. For the return tube, it's just a straight piece of 16mm OD/11mm ID aluminum tubing, about 50mm long, with a slot for an o-ring near the bottom. I bought the tubing on Amazon and took it to a local machine shop and gave them all the specs, they charged me $20 to make two of them (might as well have a spare).
All total for my conversion was about $700. I've got pictures and part numbers, I'll try to put together a post documenting everything in more detail in the next few days.
Also - VVK Suspension had an R230 V12 PS-only pump kit listed on their website, but it looks like their website is down right now. Don't know what's up with that - hopefully they're still in business, as they are the only source for a front sway bar to fit V12 R230s (their coilover kits are top quality as well). Their V12 PS pump kit became available shortly after I did my conversion.
Also - I've seen some posts from the past where a few people said they just disconnected both lines from the ABC pump, drained the ABC system, and let the ABC side of the pump run dry, but they didn't give any long term follow up. I had serious doubts that this was a long term solution, but tried this just to see how long the pump would last. It made it 350 miles before it started to significantly drag, causing the steering to start to feel sluggish/sticky. I didn't push it any further. It wasn't making any noise, but it was obvious the end wasn't too far far away.
The only thing I don't understand is this:
On SL models the hose bracket is hard to access behind exhaust shielding, and the hose can be completely replaced with part number 203.466.16.81.
Also I'd like to know more about what it really means:
On V12 R230s, the PS pressure line runs from the pump back to the rear upper corner of the engine block, then back forward to the steering rack. This is not an uncommon kind of thing, an extra-long loop coming out of a hydraulic pump is often done to help smooth out pressure pulsations before they hit the power-assisted gear. But accessing that connection point at the back of the engine block is for all intents and purposes impossible with the engine in place. You might be able to do it by lowering the engine/front subframe a bit, but it's still going to be difficult. They've apparently identified an alternat part number that can be used instead of this factory setup.
I mean will it crack the oil pan?
Using existing ABC pump, looping lines, fuses etc. has been archived but for users who are slightly less; shall we say educated the search tab is a great resource regardless of what region of the world we live.
Which loops back to what is also a very useful part of any MB discussion. Listing your location in your public info. A pump sourced in the good ol' USA will not be of use to someone in the UAE or Japan; making info requests utterly useless
Replacing the ABC with a quality coilover setup is the goal I'm not sure leaving any of the original system makes the best solution.
I was down with this until my son the Boeing Engineer convinced me it was a terrible idea.
I mean the parasitic power loss on the motor. Totally unecssary. I bought a Bosch ML55 PS pump.
Not a lot of R230 owners know that awful metallic growl the engine makes can be totally eliminated by removing the ABC pump
If you want to see why go to Youtube and find the retired MB tech who converted his own R230 and used a PS only pump
To me removing the whole ABC system would be a really large job. I'll be doing this alone in a rental place where you rent a lift hourly. So I'd like to divide it into steps while after completing each step I should be able to drive the car because I can't live my car there overnight or for a longer period.
So the first step would be this:
- Draining the system, disconnecting the lines from the ABC struts and sealing it with something.
- Removing all four ABC struts and replacing it with coilovers.
- Looping the ABC pump. Prior to the first step I must have clear understanding how to do it. The return line is already there. I just need to find the right ABC pressure line and figure out how to securely hook it to an ABC fluid tank.
- Fixing the ABC related warning on the instrument cluster.
Then the next step would include these items:
- Removing the ABC lines, accumulators and ABC radiator.
- Replacing the tandem pump with either VVK or the pump sold by the Golden Element guy. Prior to this step I need to figure out which PS pump is better and I need to obtain all necessary hoses and hardware for that PS pump.
Anyway now I need to research the nearby sway bar thread since some people including Kent from Mercedes Source and Adam from ND_72 are totally fine driving without sway bars...
https://www.vvkusa.com/products/vvk-...s-and-hardware
For example, BC coilovers only say it will fit SL55. I see Kent from Mercedessource installed Hiro coilovers that don't even bother to tell which SL model they fit. Also KW only list SL500 as the target model for their V3 coilovers.
https://shop.bcracing-na.com/product...rear-sway-bars
https://hiro-performance.com/01-11-m...sl-class-r230/
https://www.kwsuspensions.com/produc...-35225050.html
So what do you think about model compatibility of above coilovers? Will they fit every SL model or just those particular V8 models?
All the chassis are the same therefore yes regardless of the engine a coilover set would “fit”
However a V12 would need coilovers specifically designed for the weight of V12 and; the performance level of a TT or 55K would definitely demand a higher level of spring load and shock valving rates not wanted or needed in a base R230 NA 5L car.
A better question is; Should I buy a coilover set tailored to my own car or use a set that is generic in application ?
Answer is up to your level of driving experience, overall mechanical conditions and $$’s spent.
You can get nothing that rides better or a ride better than nothing. Choose your poison wisely
I’m about to start coilover conversion tomorrow! Couple of questions for everyone here -
1. Do you need to loop ABC pump if you plug the lines?
2. I’m thinking of converting to power steering pump only, but I’ll see how well I do with the conversion (Using Hiro Performance Coilovers) so here is the question, Can I drive the car a hundred yards without capping the quick connects?
3. For working without a lift, are people jacking up one wheel at a time or is it best to jack up one side, or the entire back/front?
Thank you in advance -
Jonathan
