SL/R230: Dashboard Leather Help
Old May 28, 2015 | 08:36 PM
Dostovel's Avatar
2008 SL600
Anyone know the best way to rectify my dash coming apart?
Old Jun 2, 2015 | 11:02 AM
bha's Avatar
bha
13 GL350, 14 SL550
I would pull the center vent unit, then take to an upholstery shop and have them repair it.
Normally I would do this kind of stuff on my own, but if your glue doesn't hold, you'll end up replacing the dash. You only get one shot at this.
Pull the vent and get them to properly stretch the leather a bit and glue it so it will hold. It will likely be a permanent fix (or at least many, many years before it pulls out again)
Old Jun 5, 2015 | 03:08 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
I just assumed it was padded vinyl with fake stitching. Mine sure doesn't feel like leather.
Old Jun 5, 2015 | 03:10 PM
bha's Avatar
bha
13 GL350, 14 SL550
You are right, it's vinyl (MB tex possible) and not leather.
I know in the W221 S Class a full leather dash is available, but I think only on the S600 (or was it S65?) Not sure if that applies to the SL also, but it would likely not be a leather dash unless you have an SL600.
So yes, it's vinyl but my answer is still the same. I'd have them stretch and glue it.
Weird that this happened, because I always thought the vinyl was wrapped around the corner a bit (1/2" maybe?) so it seems to have shrunken quite a bit. I suspect someone cut or tore it. When you pull the items from your dash to have it repaired, I wonder if you'll find that it's just a major cut in the vinyl, rather than the actual edge of the vinyl that you are seeing.
Old Jun 6, 2015 | 12:29 AM
next2pool's Avatar
I don't think it can be stretched. There are people who can repair molded dash panels--it involves more of a filling process with a vinyl patch. Usually a cut or split will keep shrinking and opening up.
Old Jun 6, 2015 | 06:41 AM
rune solem's Avatar
SL 55 and a GT 3000 vr4 Here's my car: http://home.online.no/~ludvs/index.cfm
Just a small info about the leather trim in the sl 55.
If you got the exclusive leather package, then you'll got real leather everywhere, including the dashboard and even the roll bar.
Old Jun 6, 2015 | 11:50 AM
next2pool's Avatar
Good to know. I didn't realize there was such an option--sounds nice.
Old Jun 6, 2015 | 01:08 PM
Wolfman's Avatar
Super Moderator
Our SL600 had Napa leather everywhere (no MB-tex); same on the S65 and Designo interiors. Our SL55 didn't but as mentioned, exclusive leather packages would be leather as well not sure if it would be Nappa or regular leather.
Either way, the repair options are similar. I would try stretching it first if it feels loose after removal of the vent cover. I would go to a specialist though, having it done wrong would be an eyesore!
Old Jun 3, 2019 | 05:20 PM
850csi's Avatar
--sold Sl55--
Guys, does anyone have any advice on how to clean the non-seat surfaces in our cars? I understand that everything in my SL55 other than seats should be MB-Tex? (What about the armrests?) Trying to figure out how to keep my ash interior clean.
