SL/R230: My 2003 Mercedes SL500 Roadster will not start
Old Jul 7, 2015 | 03:28 AM
JC0303's Avatar
2003 Mercedes Benz SL500 Roadster
Well I am getting two maulfuction codes one is the red battery light and the other is the ESP. I called some mechanics and also went onto mercedes forms site and everyone suggested that I change out the crank shaft sensor. I replaced it and still does not start. The battieres are good. Any Ideas what it could be?
Old Jul 7, 2015 | 09:13 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Try turning the wheel fully right then left to reset the ESP.
Put a charger on the rear battery overnight, and test both batteries for voltage in the morning.
I've seen it could also be a brake light switch, or ECU going bad.
Old Jul 8, 2015 | 03:31 AM
F1BHP's Avatar
sl600
I would change the front starter battery as this is a small lead acid type and cheap to replace. It could be giving you a false reading as the rear AUX battery is supplying power to it via a DC/DC converter.
