SL/R230: rear ride height abnormal - could it be the accumulator?
Could the rear accumulator be the culprit? She rides pretty stiff at the rear and leaves the road quite easily on bumps. Also the rear tyres land hard with a thump when taking on a bump at slight higher speed.
my garage tells me that i need to change all the 4 accumulators. There is nothing showing up on star. I can understand to change the rear accumulator (in case it is found to be faulty) but why change all 4 is not clear to me.
thanks for the help in advance.
A symptom of a failed accumulator is a momentary warning message in the instrument cluster when hitting a bump in the road.
Star Diagnosis can test the accumulators in a matter of a few minutes. The menu item for the test is somewhat hidden with my 2008-vintage software. Within the ABC menu I go to Troubleshooting by means of complaints or symptoms > Handling characteristics > Vehicle damping too soft or spongy handling characteristics > Pressure change during pressure release.
According to my software a failed accumulator will cause a soft ride -- not hard -- though this is contrary to what some owners report on the forums. My software states that a hard ride is caused by a faulty acceleration signal from a sensor.
I see no reason for you to fear pressing the ride height switch.
One of those pictures looks a little high to me. You can correct for it with a level calibration with Star Diagnosis.
Replacing all the Accumulators is solution IF suspension goes limp but not necessarily does that rule out some pressure loss conditions.
My question would be why would you replace parts that present the opposite characteristics?
Nothing can be absolute when asking questions online but from what little you describe symptoms are consistent to a stuck valve block. Crap gets stuck in the valves not allowing pressure to decrease to correct ride height.
A question (which causes relates to all this) is when was the last time you had the ABC fluid changed and is it almost black and smell burnt?
If so a fix would be
1. A full hydraulic fluid flush 10L with 2 hydraulic filters. 1 for a flush. # 2 for after flush for cleaned out system.
2. Remove the rear Valve block. disassemble, clean and replace.
3. SDS Rodeo and a Hydraulic reservoir top up.
Anyways, a Full SDS ABC systems check will help pinpoint pressure loss or too high pressure values.
A smart tech should've known all this or was quite possibly looking for more labor and parts ($$$'s)
bobterry99- the reason a bad accumulator can cause a harsh ride is if the ABC system senses pressure is too low (due to the accumulators being bad) it will lock all of the valve blocks so that no fluid can go in or out as a safety measure. This will result in a lumber wagon like ride for the few seconds that the valves are locked until pressure is built back up. This condition will obviously also cause an ABC warning light.
The moment ABC deactivates going over a bump the valves will close and any hydraulic cylinder in motion will sharply decelerate, and perhaps that would be perceived as harshness. At any rate, owners also report harshness even when no ABC fault is present and the system is active, so the explanations offered on this thread would not apply to those circumstances.
1. New Tandem Pump
2. All 4 new struts
3. Both new Valve blocks
4. New hoses
The only thing i did not change is the Accumulators. I do feel that she is high from the rear. Best i will post photos of the height of the car in all the three stages. Can someone please tell me what the right ride height should be in these positions for the front and rear of the car.
In my earlier reply to you I wrote that your car appears a little high. With the benefit of a closer look I would say "little" is an understatement, and it is peculiar to me that your shop does not correct this obvious abnormality. I suppose they lack the equipment to perform a level calibration or have no knowledge of it.
What else could be wrong please?
The only test I know is to stick a pencil in. 1" in is good; any more than this is bad due to failed diaphragm.
