SL/R230: 2009 SL550 Replacing Motor Mounts DIY
I'm not opposed to spending the $$$ if it's that big a deal.
Thanks,
Now for the 600 V12TT it's a completely different story
But for the 550 - no clue...P.S.
How many mounts? Which ones?
Thanks to everyone else for your replies. I intend to keep this car for a long time so I would like to get a good repair manual, can somebody recommend one? I went to https://www.startekinfo.com/StarTek/...tedDocId=11498 but it says "Please see WIS-net for MY2007 or later". I looked on eBay and found several so walled WIS software for cheap but not sure if they are worth anything.
@Sequelman: Don't bother with Startekinfo - get WIS. Those on eBay are usually OK, just check feedback and ask questions. I noticed many of them say that an Internet connection is required - I'd like to know if that's just a one-time need for their licensing, or if they are doing something else (it should not be needed full time). BUT...if you intend to DIY work on your SL, you really need SDS. The best version to get is with a hardwired multiplexer with the built-in RS232-to-RS485 interface and the software on a "virtual" machine. This is the most flexible way to use it and the hardwired (vs. wifi connected) multiplexers seem to be less prone to failure. If you shop around, you can usually get it for around $350 (you supply the laptop) or for about $700, you can get a turnkey system with the laptop (Dell D630 or similar). Checkout mrcartool.com - that's where I bought my last unit.
