SL/R230: Jump start/electrics problem
I havent driven it in a couple of weeks. The fob no longer opens the car. I used the key and gained access. The key will slot into the ignition but will not turn. I thought it could be the front battery but attached jump leads and nothing happened. I thought it might be the rear battery. However I cant access the boot. The key wont turn and open the boot. Erm...help? Any ideas?
Cheers
If the key won't turn in the ignition switch, then possibly the switch is not powered. Check for a blown fuse in blocks F32 and F33. Details are in the PDF file attached to this post.
I can't jump the car from the front battery under the hood? I need to jump from the rear battery in the boot/trunk?
K57 will remain energized for about 5 minutes after the engine starts. If it were me I might wait for the relay to de-energize before removing the jumper cables after a successful start.
No. Refer to page 31 of the PDF file mentioned in my first post and note that the K57 relay connects the front and rear batteries together in parallel in the case where the rear battery is flat.
Will attempt this in the evening and report back!
Further, jumping from the rear needlessly exposes the vehicle electronics to voltage spikes that can cause damage. On my car a plastic cover which attaches above the positive post of the rear battery cautions to ONLY jump-start from the front battery.
There were no such changes. From the beginning of R230 production the K57 relay connects the two batteries in parallel in the event of the rear battery being below about 10.8 volts (weak). If the front battery is weak, then the vehicle can not be started unless a little trick is employed: disconnect the rear battery, turn the ignition key to position 2, and within 30 seconds reconnect the rear battery and start the engine.
I cant seem to open the hatches behind the seats. Either of them. I need to get access to the fuse box there and cant open them. They seemed to be fine before this problem. The same is true of the glovebox as well.
Any suggestions?
moretech
Something like this be ok to charge the rear?
http://www.halfords.com/workshop-too...attery-charger
Or this?
http://www.halfords.com/workshop-too...les-up-to-2-0l
Im after the quickest charging option if there is a choice as I have it booked it to see a MB specialist in about 24 hours and will only be able to start charging in around 10 hours.
Thanks guys.
moretech
Through MY2008: http://benzbits.com/R230/BatterySystem.pdf
MY2009+: http://benzbits.com/R230/BatterySystem2009.pdf
I think that as of MY2009, the system was altered so that both front and rear batteries can "help" each other, but prior to MY2009, the only option was that a weak consumer battery could be supplemented by the starter battery, but not vice-versa. I could be wrong here, but that's how I have always interpreted the difference. .
Nothing I read suggests this is the case. Operation of the K57 relay is solely dependent upon the "on-board power supply voltage" and never the starter battery voltage. Note that in this document the rear battery is referred to as the "on-board electrical system battery".
The battery cutoff relay is controlled depending on the state of the
on-board electrical system. Depending on the state of the on-board
electrical system, the on-board electrical system battery and the
starter battery remain separated by the battery cutoff relay or are
connected in parallel.
A distinction is made between the following on-board electrical
system states:
- Normal starting mode
- Normal mode
- Emergency starting mode
- Emergency mode
- Shutoff phase
If there is no undervoltage, the on-board electrical system battery and
starter battery are separated (normal and normal starting mode).
If undervoltage is detected, the system switches to emergency and
emergency starting mode. The on-board electrical system battery and
starter battery are connected in parallel by the battery cutoff relay.
As for charging the consumer by connecting to the starter battery, I don't see that working unless the BCM has switch on relay K57 to put the two batteries in parallel. It does that in an undervoltage situation, but I am not sure what that is. The WIS doc mentions that after the BCM cuts-in the starter battery, it won't cut it out until voltage reaches 12.5v for 3-7 minutes (depending on the severity of the undervoltage situation). I do see it mentioned that Stage 1 low voltage is M< 10.6v. Maybe that's the threshold? If so, that means if the consumer battery voltage drops below 10.6v, and the K57 relay is activated to put the batteries in parallel, the you could charge the consumer battery via connection to the starter battery.
https://mbworld.org/forums/clk-class...rill-lock.html
Having said that, it is fine to charge the consumer battery without disconnecting anything. In fact, many people keep connect a C-Tek charger on theirs so the consumer battery does not drain after several days (or weeks or months) of being garaged.
Regarding the hard key mechanism on the trunk lock, yes, it does just move a plastic lever into the mechanism, but that plastic level allows the handle to then unlatch the lock. In other words, you insert the hard key in the lock, rotate it counter-clockwise, and while holding it there, squeeze the handle. The latch should then open - no electricity or pneumatic pressure needed.
I have jumped an R230 once and other modern Mercedes perhaps a dozen times with no ill consequences. It's my belief if proper procedure is followed there is very little risk.
Also, I agree 100% with you on the car being designed for the possibility of jump starting. I hear so many people claiming that jumping will blow electronics and that's just plain wrong. Proper jump starting or charging won't damage anything. I've probably jump-started at least 100 MBZ cars and not damaged a single one. One thing that does happen is that a dead battery can act like a giant resistor so that jump starting won't provide enough amperage to the starter. In that case, disconnecting the dead battery works like a charm (I had to do that many times for cars sitting in the storage lot).
