SL/R230: right rear brake rattle when first take off
Do you have stock wheels or spacers on the rear?
My bet is your lug bolts are a little too long and hitting the parking brakes springs. If so, fix it before it causes more damage.
Report back what you find. We can compare with the standard bolts we mostly all have.
If I remove rotor and not change disc pads I do not have to shut brake system down as long as door or not open .....Right?
Bolts sound about right, but I have not compared to mine.
When you removed the caliper, did you pull the brake disk too? The emergency brake is inside the rear disk and is a drum type brake.
Could be something inside the drum making the noise. Look inside the drum.
My C32 had a torn boot on the CV, which I was able to seal up without removing, but I have plans to replace the boot.
I would find a suitable replacement part, or even a used low mile shaft unit (if you trust the source).
You might want to pull the shaft and replace the parts. Here is a DIY for the shaft on a C32, not an R230...
