SL/R230: "Wake up" signal to the sound amplifier
Here is a MOST inteface which may or may not incorporate wake-up: http://www.installer.com/item/displa...?it=most-hurmb.
I found a few docs in the WIS about the wake up function.
This is how I believe it works.
When the key is turned on or the power button on the radio is turned on, the audio gateway sends out a short duration electrical pulse on a separate wake up line to each component that is part of the MOST ring. Each component then replies optically to the audio gateway over the MOST ring. If the audio gateway does not receive a reply from a specific component, it then makes several attempts to wake up the component optically.
There is one important contradictory sentence in the first paragraph in the Most wake up description: In order to do this, the audio gateway control unit (N93/1) transmits a light signal via the MOST ring. Read the "wake up most" pdf I've attached and I think you may agree with me.
If this were the case, then the rest of the document doesn't make sense. The D2B wake up document is very similar but it clearly states that the master unit sends out an electrical pulse on a separate wake up line to all components to wake up the D2B ring. I believe the master unit is the Radio in this case.
None of this really helps as the WIS doesn't say exactly what the electrical wake up line signal is. I've also attached a document from one of the forums which says it is a 12v signal. Other threads I've read says it's a 5v logic signal.
I've attached the WIS documents and one document for a W211 that I think is relevant.
Bob, if the opt1 were to put out a wake up signal, that would certainly be the ticket. For $549.95 I would certainly think it should, but I haven't read anywhere that it does. Haven't read that for the xtrons unit either. I wonder if adding an Audio Gateway just for the wake up signal would do the trick.
The Electrical Troubleshooting Manul (ETM) states there is "no reliable test" for measuring the signal on the wake-up line. Perhaps with an oscilloscope you could observe and characterize it and reliably duplicate it.
I believe adding the Audio Gateway could provide the needed wake-up function. If so, you may need Star Diagnosis to code the gateway with the MOST ring architecture.
If I were going to replace the COMAND in my '03 with a modern aftermarket unit, then like you I would choose to keep the factory amp and speakers. Those components have been customized to work with each other in one specific vehicle. I don't think I could substitute aftermarket components for those originals and expect the sound to be as good. Caveat: an impressively loud bass that is distorted and exaggerated is not my idea of good sound.
With the audio gateway, I was just thinking about connecting switched power to it then connecting the blue/black wire to the amp and nothing else. My hope would be that when the AGW turns on, it will send the electrical wake up signal to the amp and turn it on.
Any updates on this? i have the same issue, i can't seem to process a "wake up" after I installed an aftermarket android unit..... :S it takes 5-7 min for sound to start coming ... am sure it's something related to the wake up signal
also, aftermarket stereo worked for so many others just fine with a decoder, why it it only me and u?
I tried before it connect the ACC of my decoder device, to the wake up signal, and it worked, BUT, this has kept the decoder the CAN BUS working overnight and caused battery drain. The wake up line from the car harness is hot all the time and any device you connect to it is going to stay awake overnight.... did you mean to connect the B+ of the decoder to the wake up line? or the ACC of the decoder to wake up line?
In about ten days I'll be taking some of the interior out of my car and should have easy access to the X30/14 connector. I'll connect an oscilloscope and should be able to tell what that wake up signal looks like. Then a very simple electronic circuit can be made so that the ACC signal from the electrical/optical interface replicates the wake up just as if it had come from COMAND.
As you guys have mentioned this is supposed to Wake-Up the AMP. But it does not. As marko69 reported it comes on after about 5 mins. So clearly whatever signal is required it's not happening.
Has anyone found and answer. I been doing web search for days.
