SL/R230: ABC Workshop Warning
Old Apr 11, 2018 | 04:12 PM
JamesC7242's Avatar
SL 55 AMG
I have a 2004 SL55 AMG with about 74k on the odometer. This is a very mint car, but last week when I started it for the first time in a few weeks I saw "ABC workshop" message on my center screen in my dash. The ABC system seemingly is working fine lowering and raising the car the way it should, but I am worried still about the warning as I know ABC is not cheap. Anyone have any ideas?? Thanks!
Old Apr 11, 2018 | 04:34 PM
FxFormat's Avatar
SL 600
First thing first is check the fluid level? Do you know how to do that? Have the engine running and pull the dipstick out, it should be at the middle mark, when engine off it should be at the highest mark on the stick. Next you need to check the car for leaks, gotta pull the under panel to see the lines, check all the struts as well.
Old Apr 12, 2018 | 07:08 AM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Follow suggestions from FxFormat to verify fluid levels and for leaks. If that checks out then don't worry. It is very common for ABC systems to leak down over time and as long as the system comes right up after starting the motor, it's normal . I know it is very troubling to see that red ABC warning but not to worry! See attachment for some comfort!
Good Luck,
Bob
Old Apr 12, 2018 | 10:15 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
It is also possible that one of the accumulators has blown, and needs replacement.
First to go seems to be the one just downstream of the pump, in LF fender well for early cars, on the pump for later cars. Causes a "hum" by the brake pedal.
A scan with an SDS is a good way to ferret out the issue before you start throwing parts at it.
Good luck and keep us posted.
Old Apr 12, 2018 | 11:30 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by JamesC7242
...last week when I started it for the first time in a few weeks I saw "ABC workshop" message on my center screen in my dash.
When you start the engine the ABC controller monitors the rise in hydraulic pressure. If a threshold is not achieved in a given time you will get a warning like you saw. If this is the case it could simply be a glitch in the pressure sensor that won't happen again and is nothing to worry about.
Old Apr 12, 2018 | 11:51 AM
Jaap's Avatar
2006 W221 S500L M273
If you do check the fluid level or fill the fluid, clean the area of the reservoir thoroughly first.
That system cannot deal with any dirt.
any. dirt.
Old Apr 12, 2018 | 09:25 PM
White Spyder's Avatar
2003 R230
Change the filter and do a fluid flush. ,
Old Apr 16, 2018 | 01:53 PM
JamesC7242's Avatar
SL 55 AMG
This seems to be what had happened... thank you!
Old Apr 16, 2018 | 09:47 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Mine does this after sitting for a few weeks. One of the corners has sagged or leaked down a bit and the red ABC warning will come on upon starting. Just hit the raise/lower button and the system will level and the light will go out immediately. The leak down is so slow and minor that I don't feel compelled to do anything about it yet.
